Topic: Sound popping Roland DJ 202
bu4ka_ControlleristMember since 2010
Hello, guys
when i play songs on my controller`s sound card, after 40-50 minutes appears sound popping. The sound popping is not too loud, but i and the crowd can hear it. I tried to increase the latency but the problem did not disappears.
When the music is on pause, the sound popping missing.
The problem is only when i use controller`s sound card.
Any suggestions?
geposted Tue 13 Mar 18 @ 5:15 pm
Is this a Mac or PC? You have the latest firmware/drivers installed? Are you using ASIO drivers or WASAPI? If you use another controller, do you here the same noise?
geposted Thu 15 Mar 18 @ 5:48 pm
Use it on windows 10, latest driver, WASAPI.
The noise is only on the Roland DJ 202
Until now i change my battery plan to "high performance" and made USB`s do not sleep, but the noise is there.
geposted Fri 16 Mar 18 @ 7:03 pm
