I tried it but i just got the following message: The fix is not required on your system
geposted Thu 12 Jul 18 @ 8:43 pm
If it isn't seen in device manager then, either the usb cable is a dud or perhaps antivirus is stopping the device from installing the driver.
geposted Thu 12 Jul 18 @ 8:55 pm
Finally it appears on the device manager.
The usb cable is brand new and i also tried another one.
Also i stopped the antivirus and anti-malware programs that i'm using.
But still no luck
But still no luck
geposted Thu 12 Jul 18 @ 9:28 pm
Hi,
i am using pioneer ddj sb3
and suddenly my device is not functioning properly with virtual dj software like tempo nd few other knobs are not responding accordingly when mix . volume knob doesnt work properly it stays on fix position even when i slide it up ,
please guide me
please guide me
geposted Sun 22 Jul 18 @ 5:24 pm
When i connect the device laptops gets hang ..if i update firmware then if i have connect back to serato
geposted Mon 27 Aug 18 @ 8:08 am
I have the same problem as a previous user, I'm trying to use 4 decks with my SB3 and even when I'm using the 4 deck layout I can't get my controller to work on decks 3 or 4. I've tried any possible controller mapping techniques I could think of but nothing works. Could someone please tell me how they got theirs to work? Thanks
geposted Tue 18 Sep 18 @ 1:32 am
hi guys.. i need help.please help me get a mapping for sb3 please
geposted Tue 22 Jan 19 @ 1:37 am
Please read the first message in the thread (or the thread title).
geposted Tue 22 Jan 19 @ 5:03 pm
I connect my sb3 to the laptop the driver instilled but it shows failed to connect when I open virtual dj 2018
Please help
Please help
geposted Wed 03 Apr 19 @ 6:09 pm
See if another application running at the same time which could claim the device, or another instance of VirtualDJ in Task Manager.
geposted Wed 03 Apr 19 @ 8:37 pm
I have a DDJ SB3 as a backup device and tried some of the functions. FX Fade - both Backspin modes does not work. And the pad scratch feature, is that really all? Most of them sound equal.
UPDATE
With DJay Pro Windows the backspin FX work. Pad scratch sound also not so cool
UPDATE2 :)
Four decks mode works too with Djay Pro but noth with VDJ
UPDATE
UPDATE2 :)
geposted Fri 03 May 19 @ 8:58 am
UPDATE
UPDATE2 :)
UPDATE
UPDATE2 :)
You may want to read this http://virtualdj.com/manuals/hardware/pioneer/ddjsb3/setup.html
It will explain how all the functionality works with VDJ
geposted Fri 03 May 19 @ 12:49 pm
I have a sb3 music is playing fine out of my computer but I can’t hear anything out of the
master output just the headphones can someone help me
geposted Mon 10 Jun 19 @ 8:20 pm
Does you audio config set like this?
geposted Mon 10 Jun 19 @ 8:33 pm
i just go my pioneer ddi sb3 and i can't figure out how to setup my controller to work with virtual dj i already updated it and bought a license for virtual dj but it doesn't work
geposted Thu 11 Jul 19 @ 12:54 am
/Users/90307887/Desktop/Screen Shot 2019-07-10 at 7.58.49 PM.png
/Users/90307887/Desktop/Screen Shot 2019-07-10 at 7.58.40 PM.png
no mine doesn't look like that this is what i have
geposted Thu 11 Jul 19 @ 12:59 am
When you start VDJ it should automatically detect the SB3 and ask if you want to use the audio interface.
Did that not happen?
If it didn't (or you ignored it) then simply set up the audio config as shown. There should also be a large 'SB3' button (as shown in the pic) that you can click, which will set the audio up correctly.
geposted Thu 11 Jul 19 @ 4:24 pm
Gunite6390 wrote :
does the the Virtual dj also support the FX Fade feature that pioneer promotes with the mixer? or is that a serato feature
geposted Wed 04 Sep 19 @ 3:51 am
That question was answered in the very next post.
djdad wrote :
Same as the Scratch and Trans modes, the FX Fade is a hardware Pads mode (part of the unit's firmware) , so yes, it works the same in VirtualDJ
http://www.virtualdj.com/manuals/hardware/pioneer/ddjsb3/layout/pads.html
geposted Wed 04 Sep 19 @ 5:35 am
Hello,
I have a problem with the SB3.
When I turn the Trim to the maximum, the sound level fluctuates during playback.
Tested on FX1 and 2, tested after reboot .. same thing..
For your information, I'm using the last version VDJ PRO on MAC OS X Catalina
I'v tested on SERATO and no problem ... All is working fine.
Any Ideas ?
Thank you
Any Ideas ?
Thank you
geposted Tue 26 May 20 @ 3:52 pm
