Topic: Broadcast
viggerzControlleristMember since 2016
Hi for some reason broadcast pc to pc is not working for me. I have mp3 selected in options. I goto the broadcast to test it and it says broadcast is active although I cant hear any sound coming through....
geposted Fri 23 Mar 18 @ 6:08 pm
check broadcast by opening link under broadcast tab and following link to virtualdj website in browser. if it gives you an error then you need to go into windows firewall settings, open port 8000 and make VirtualDJ an allowed exception so it can get through firewall settings
geposted Fri 23 Mar 18 @ 7:40 pm
ok thanks i think i need to open port 8000
geposted Sat 24 Mar 18 @ 1:39 pm
i opened port 8000 but nothing happens when i listen on other computer. it says i am broadcasting
geposted Mon 02 Apr 18 @ 2:25 pm
Same problem. 8000 is forwarded and site says I'm broadcasting - no warnings - yet no-one can hear.
geposted Mon 10 Sep 18 @ 11:16 pm
