Hi y'all, I have a question. Whenever I select 50% pitch on the PLX, VDJ shows the pitch range up until 16%. Like once the fader gets past that 16%, It does not show the pitch moving. Can anyone help me out? Thanks!
geposted Tue 27 Mar 18 @ 7:23 pm
If you have VDJ set to 16% then it won't go past that if you have the PLX set to 50% (etc).
Obviously VDJ has no way to tell what pitch range you have selected on the turntable, so if you're going to select a different range on the turntable, you also need to select the same range in VDJ.
geposted Tue 27 Mar 18 @ 8:06 pm
