Topic: Going mad
I have no default folders in filters how do I get to the compatible songs folder
geposted Sun 01 Apr 18 @ 10:09 am
If you have hidden the entire filter folder, you can get it back using the dot menu on the bottom left of the screen
If you have deleted them, and just want the "compatible songs" one back, you can recreate it. The script for it is:
bpmdiff<=4 and keydiff=0
geposted Sun 01 Apr 18 @ 10:38 am
Thanks but neither deleted or hid them just weren’t there to start with just got virtual dj8
geposted Sun 01 Apr 18 @ 1:51 pm
I don't know what you guys did in development, but it messed up my searches in this new version 8.2 b4204. I typed in a song from my database and nothing. Good thing I wasn't at a gig. The version before that was working fine.
geposted Sun 01 Apr 18 @ 3:21 pm
Oh, then you just got to learn the new software
v8 is nothing like v7 - it was complete re-programmed
Filter folders are under filters in v8:
geposted Sun 01 Apr 18 @ 4:12 pm
The new one is too - so something else must have happened
But please don't hijack threads about other subjects
geposted Sun 01 Apr 18 @ 4:14 pm
Ok, I fixed the problem. I used the remove missing files option and that fixed it.
geposted Sun 01 Apr 18 @ 4:19 pm
Therefore you must have either moved or renamed a file or files outside of Virtual DJ.
If you do that, the VDJ database won't be aware of the change. Any renaming/moving of files (i.e. data) must be done from within VDJ so the database is updated.
geposted Sun 01 Apr 18 @ 5:21 pm
I apologize as i'm still pretty new to the community, the so called hijack was unintentional.
geposted Mon 02 Apr 18 @ 2:58 am
