Topic: Keep getting 'renaming' all the time
Using the latest early access build I keep getting the message 'renaming' flashing up where you usually get the info about scanning, streaming etc. I think it started with the previous early access build. The icon in the dock (I'm on a Mac) shows a progress % of 100% to. I haven't changed hard drive or renamed any files myself outside of VDJ so I 'm not sure what VDJ is doing?
geposted Sun 01 Apr 18 @ 10:18 am
It can also happen when opening a playlist or virtual folder which contains some files that had been moved
geposted Sun 01 Apr 18 @ 11:43 am
As I said I haven't moved any files at all. Will it eventually 'right' itself? Will it cause VDJ to crash?
geposted Sun 01 Apr 18 @ 1:21 pm
It should go away once finished, does it stay there for you?
geposted Sun 01 Apr 18 @ 1:24 pm
I see it every time I'm using VDJ. I've got quite a few virtual folders and a large collection so is it doing something to all the files? I'm not actually sure what it's actually doing?
geposted Sun 01 Apr 18 @ 1:30 pm
Me too, i have it all the time, really annoing and i do not know what it is doing. Why can I not stop this proces?
geposted Sat 18 Jan 20 @ 2:00 pm
You can hover your mouse over the 'renaming' to see on which virtual folder or playlist it might be stuck.
geposted Sat 18 Jan 20 @ 3:48 pm
