Topic: output settings
Hello all,
Can anyone confirm what settings I would need for the following....
American Audio VMS5 is connected to laptop and then from the VMS5, rca output from master or booth to a stereo mini jack into a speaker?
I usually use xlr cables but the set up above is for something new.
Might be simple but just couldn't figure it out.
Thanks
geposted Wed 04 Apr 18 @ 11:20 am
user14499638 wrote :
Hello all,
Thanks
From master RCA that should be the same as your XLR setup
Most controllers simply send the mast output to both master XLR out and master RCA out at the same time
geposted Wed 04 Apr 18 @ 2:23 pm
Thanks for the advice. I spent my lunch break re configuring the venue set up so I can just run via xlr. All tried and tested now.
geposted Wed 04 Apr 18 @ 2:31 pm
geposted Wed 04 Apr 18 @ 5:52 pm
