Hi, I have searched the forum but I am not sure what I am really looking for so I thought I would just post and describe as best I can.
I would like the video of each channel to enable in the main screen when I move the channel fader, not the crossfader. I do a lot of karaoke and I always prep songs in the deck window before moving the cross fader over to enable it in the main screen but I would like this to happen when I move the channel fader up, not fade in and out, just enable and disable.
Is this possible?
Thanks.
Is this possible?
Thanks.
geposted Sat 07 Apr 18 @ 8:54 pm
This works when you dont use the crossfader or having it in the center.
you can see that you just search for volume.
geposted Mon 09 Apr 18 @ 4:34 pm
Also, if you don't want any fading in video mixing (between the 2 tracks), then you could select the "None" Video Transition.
geposted Tue 10 Apr 18 @ 11:36 pm
Thanks for your reply, video link is fine but I don’t want any fading on the video as I move the fader, I just want it to appear and disappear.
geposted Thu 12 Apr 18 @ 9:37 pm
I tried to include this in the volume of the ddj-1000 map but it wouldn’t work.
level & level 100% ? video_level 100% : video_level 0%
Then I was going to change the % of volume to my liking.
geposted Thu 12 Apr 18 @ 10:02 pm
Try ..
level & param_bigger 90% ? video_level 100% : video_level 0%
Change the 90% value to the one you want the video to "disappear"
geposted Fri 13 Apr 18 @ 10:06 am
Old thread, but if i do this on one pc ok, doing on another when fader is pulled back all way down the transition to other video never stops unless i actually stop play? Must be a setting i have on one pc but not the other?
geposted Thu 09 Jul 20 @ 11:05 am
Nr. 4 : VIDEO OUTPUT MENU https://www.virtualdj.com/manuals/virtualdj/interface/mixer/video.html
Things to check..
Video Fade-to-black -> on Volume Sliders
Video Crossfader -> Manual, Linked to Audio, Smart
Things to check..
geposted Thu 09 Jul 20 @ 2:38 pm
