Hi, downloaded the latest software through VirtualDJ 8 now it doesn't startup anymore,...
While the controller is turned off it starts up but when turning on the controller Virtualdj disappears.
Help!!!
Rolled back to 8.2.4204. and it works again.
Rob Huurman - Rojo Sound & Light
Help!!!
geposted Fri 13 Apr 18 @ 9:11 am
Everything working fine here with b4251 and MCX8000
Did you also install a Windows 10 update as that seems to be screwing up the connection of some midi controllers?
geposted Fri 13 Apr 18 @ 9:48 am
the new windows 10 updates has some sort of HID update in there as well maybe that is the culprit?
well it had a HID update for me anyways... maybe not everyone needs that.
geposted Fri 13 Apr 18 @ 10:15 am
What settings do you have for ultraLatency and samplerate in options?
samplerate should be on Automatic, ultraLatency should be on yes.
geposted Fri 13 Apr 18 @ 10:17 am
