We have a MacBook that's having some issues in one user account so I started switching things over to a second user account on same computer. Am going to just delete first account when second account is up and running. When I try to launch Virtual DJ in second account it's asking for a serial number. Can I find this in the first account somewhere?
TIA!
TIA!
geposted Fri 13 Apr 18 @ 4:44 pm
Well if you're a genuine license holder then the serial number would be registered to your account here, and your username would have "Pro Infinity" below it.
If you bought VDJ using a different username then you need to log in here as that user to see the info.
geposted Fri 13 Apr 18 @ 5:21 pm
Thanks @groovindj.
No, it wasn't purchased under this community account. Is there any way to find the serial in the other user account on the Macbook?
geposted Sat 14 Apr 18 @ 8:23 pm
If you don't know your serial number (why didn't you make a note of it somewhere?) then as I said earlier, you'll need to log in here as the username it was purchased under, to see the serial number in your account.
geposted Sat 14 Apr 18 @ 8:40 pm
