Hi Guys,
If one of the song gurus can help me out here, what i need to do is load a specific song to the non playing deck using a button. I have a few scratch sounds that i wanna load to the non playing deck with a button during my sets, without having to always search or go to the folder its in.
so i want to press button A and then = Load specific song to non playing deck,
Thoughts?
Chad
Thoughts?
Chad
geposted Fri 13 Apr 18 @ 8:52 pm
The easiest way would be to load it as a sample and use a pad or keyboard shortcut.
geposted Fri 13 Apr 18 @ 9:06 pm
I dont want to play it as a sample I do actual scratch routine from time to time so need platter control like a normal song.
geposted Fri 13 Apr 18 @ 9:15 pm
assign to a custom keyboard or button
deck 1 play ? deck 2 load "where ever the path for the song.mp3" : deck 1 load "where ever the path for the song.mp3"
just change the BOLD to the correct path of the file.
geposted Sat 14 Apr 18 @ 6:26 am
Will try this and update the thread.thanks :)
geposted Sat 14 Apr 18 @ 6:50 pm
great this worked.. yay
geposted Sat 14 Apr 18 @ 9:53 pm
