Topic: Can't Split Audio to two separate channels
vjred76PRO InfinityMember since 2013
I am using VDJ 8 and a Focusrite Scarlett 2i4 to run audio into a QSC TouchMix 16 for my karaoke setup. (2015 Macbook Pro)
I am trying to route deck 1 to channels 1&2 and Deck 2 to channels 3&4 so they can be on separate channels on my mixer. No matter what I have tried, I can only get audio to come thru on channels 3&4. Nothing on 1&2. EVER. Am I missing something here?? Help.
I never had this problem with my older macbook.........
geposted Sat 14 Apr 18 @ 9:42 pm
Well what have you tried? Please either describe the VDJ audio config(s) you've used/are using, or post screen grabs.
We have no way of knowing what you've tried.
geposted Sat 14 Apr 18 @ 10:12 pm
doesn't Focusrite Scarlett 2i4 only have 2 inputs and 4 outputs? maybe i'm wrong?
if you are attempting DVS you need 4 in 4 out minimum.
if you are up to something else well tell us :-)
geposted Sun 15 Apr 18 @ 2:05 am
