Topic: V84204 XDJ-RX2
rebbiePRO InfinityMember since 2012
So i have my pioneer XDJ-RX2 version 1.30 updated also the drivers 14 /sep /2017 installed
and vdj version 84204
All buttons work , exept the play button won t ?
this one is on win 10 .
anyone ?
geposted Sun 15 Apr 18 @ 9:57 am
And the loaded track plays/pauses if you use the PLAY button from the skin ?
geposted Sun 15 Apr 18 @ 10:36 am
No, also don t work .
geposted Sun 15 Apr 18 @ 10:39 am
Then something is wrong with the Audio setup. Can you post a screenshot of the VirtualDJ Settings ->AUDIO tab ?
Any chance the jogwheel is somehow "touched" and track is on hold ?
Map a custom button on the default skins as .. touchwheel_touch
and see if its ON when jog is touched and OFF when not.
Can you also confirm that the issue is present with "factory default" mapping ?
geposted Sun 15 Apr 18 @ 10:42 am
Can you also confirm that the issue is present with "factory default" mapping ? yes it is
geposted Sun 15 Apr 18 @ 11:38 am
I can see you have the word 'fout' on the very right hand side of your settings, so there is a problem with the ASIO driver.
You should ensure that the RX2 is not set as default audio for Windows 10. Use your internal audio interface for that, not the RX2.
geposted Sun 15 Apr 18 @ 11:55 am
Yes ,it is a problem with the asio driver , when i set it on wasapi it works,
geposted Sun 15 Apr 18 @ 12:34 pm
