Topic: Issues with the fader volume.
ZiggyMCHome userMember since 2018
Hey y'all, I'm having issues with the faders not picking managing the right deck (specifically #2). When I'm using four decks, there's no issue (or if anything one I haven't come across). When I'm using two (the default option) I'll have two songs that'll play yet when I try to use the fader only #1 works. It'll turn down/up both songs both simultaneously and separately via cross fade. What do I do in order for the second fader #2 to pick up the second deck?
geposted Sun 15 Apr 18 @ 7:07 pm
Are you just using VDJ and the on-screen faders, or are you using a controller?
If it's a controller, which one?
geposted Sun 15 Apr 18 @ 8:11 pm
I'm using a controller, the DDJ-SZ from Pioneer.
geposted Mon 16 Apr 18 @ 7:02 pm
