Hi Guys,
So i have 4 hot cue buttons that has its own LED's, they are green and red as far as the mapping goes, and what i can see. what i need it to do is for them to blink red when an effect is on. the 4 hot cue buttons do different things depending on a cycle button. below is the current mapping.
Hot_Cue1_Button = var 'mode' 1 ? var 'save' ? sampler_rec : effect "cut" active : var 'mode' 2 ? loop 1 : var 'save' ? set_cue 1 : var 'clear' ? delete_cue 1 : hot_cue 1
Hot_Cue1R (LED) = var "$sample" ? off : hot_cue 1
basically i want the hot_cue1R blink red when effect cut is on and go back when the effect is off,
Chad
Chad
geposted Mon 16 Apr 18 @ 8:39 pm
