Good day I am using High Sierra was able to record my videos and music mixes with audio, but I can't now. Is there any fix to this or are you'll going to send out an update.
geposted Thu 19 Apr 18 @ 11:23 am
Your account stats show that you are using a Pioneer DDJ-SZ.
Is your Audio Setup in VirtualDJ set like this http://www.virtualdj.com/manuals/hardware/pioneer/ddjsz/record.html (with a record line assigned to Channels 9.10 of the DDJ-SZ sound card) ?
geposted Thu 19 Apr 18 @ 11:54 am
yes i have the recording channels as 9 and 10 on the pioneer ddj sz
geposted Fri 20 Apr 18 @ 12:56 pm
Still nothing
So, what happens when you click on the REC button ? Do you get any kind of message/error ? Do you get any activity on the Record VU meters on the skin ?
What format (filetype) are you using for your recorded files ? Have you tried other ones ?
geposted Fri 20 Apr 18 @ 12:59 pm
I have tried all formats and nothing I really use the recording to do my video mixtapes but that as well not recording. I get the message waiting for sound to begin recording
geposted Fri 20 Apr 18 @ 1:09 pm
Can you re-install/update both drivers and firmware from here .. https://www.pioneerdj.com/en/support/software/ddj-sz/ ?
geposted Fri 20 Apr 18 @ 1:19 pm
Also, from the DDJ-SZ Utility (should be at [Applications] > [Pioneer] > [DDJ-SZ] > [DDJ-SZ Settings Utility].) , make sure the USB 9,10 is set to MIX (REC OUT) as per the image below
geposted Fri 20 Apr 18 @ 1:25 pm
Finally got it to record but the audio is about one third, How do I raise the volume on my recording. My master and faders are on yellow,
geposted Fri 20 Apr 18 @ 1:43 pm
ok I got everything sorted out, Thank you for your patience.
geposted Fri 20 Apr 18 @ 1:50 pm
What do you have in VDJ Settings for zerodb ? "default" or a lower value ?
Also, from the DDJ-SZ Utilities, the default output level is -10db. See if there is a value closer to 0.
I'm having the same problem. followed the same steps above, and I'm not getting it to record. It still shows. Waiting for sound, but all my volumes are up, and the settings are the same as shown.
geposted Sun 03 Feb 19 @ 9:48 pm
