I found a possible issue with effect order
As I understand it, the order is that whatever you trigeger first gets send into the second effect you trigger and so on
I've tried triggering the mobius effect first, and then cutting it up with the cut effect
That works the first couple of times after VDJ has been started
But then it stops working, and the mobius effect is no loger affected by the cut effect, until VDJ has been restarted
Like shownhere
First it works 3 times (even though the length changing is a little strange)
Then I go back and forth with the activation order
And then it stops working even when activating the effects in the order that worked in the beginning of the video
Like shownhere
geposted Sat 21 Apr 18 @ 2:32 pm
It's seems to be the same when combining noise and cut effect - only works the first time
geposted Sat 21 Apr 18 @ 2:41 pm
True, is works well on the first try on the same loaded track.
geposted Sat 21 Apr 18 @ 5:42 pm
