Topic: File Operations - Copy to
... doesn't seem to work for me (8.2 build 4204)
Selected all (ctrl+a) songs in a Virtual Folder, right click > File Operations > Copy to...
Destination is a folder on my drive but nothing happens. No tracks are being copied.
Known bug ?
geposted Sun 22 Apr 18 @ 5:43 pm
All tough when songs are in a 'playlist', it works.
(select the playlist, right click > export to...)
geposted Sun 22 Apr 18 @ 6:08 pm
I've brought this issue up before, several times, but the "bug" is still there...
If any of the tracks in your folder have a red X (i.e. the database can't find them) then the copy will fail. No warning message, no clue as to what the cause is - it just won't work. Ideally it would ignore the missing files and copy the rest.
geposted Sun 22 Apr 18 @ 7:15 pm
thx groovindj, that was indeed the cause. 2 files in the folder had red cross.
Removed the red-cross-files and 'copy to...' worked.
geposted Sun 22 Apr 18 @ 8:04 pm
I have no idea why, but it will not work under ANY circumstances for me. And I followed all the steps. Won't move. Won't copy. Won't export from playlist. No red X's. ???
geposted Mon 23 Mar 20 @ 8:18 pm
Solved my own problem: the system can only copy so much at a time. You may need to divide your copy sessions up into several sessions of about 100 items per copy.
geposted Mon 23 Mar 20 @ 8:28 pm
I’m trying to copy 600K songs to new HD but it closes out each time. 100 at a time o no….
geposted Wed 27 Apr 22 @ 12:32 pm
