Hi,
I have used LOCODOG's flanger effect volume leveling script and it seems to be working well on the skin, when i select flanger on the skin it works perfectly where the volume is reduced when its on and then goes back to normal gain once flanger is off. however when i plug in the controller and use a button in the controller for the same purpose the gain doesn't come back to normal, it stays on that -15, and if i click on it again it goes down by another -15
effect_active 'flanger' ? effect_active 'flanger' & get_var "resetGain" & param_cast & gain : set "resetGain" '`gain' & effect_active 'flanger' & gain -15%
any ideas?
thanks
chad
any ideas?
thanks
chad
geposted Tue 24 Apr 18 @ 5:51 pm
Controllers usually have gain sliders as well that interfere with the software.
You should change your script to:
effect_active 'flanger' ? effect_active 'flanger' off & gain_relative +15% : effect_active 'flanger' on & gain_relative -15%
geposted Tue 24 Apr 18 @ 6:15 pm
sorry, i see that u add 15 back there :), so i will try this out and see.
thanks
thanks
geposted Tue 24 Apr 18 @ 6:22 pm
Tried this one, the flanger turns on but i dont see the gain moving at all.
geposted Mon 30 Apr 18 @ 8:19 pm
This script still didnt work unfortunately :(
geposted Fri 08 Jun 18 @ 6:52 pm
i am sure locodog replied but i dont see his comment :(
geposted Fri 08 Jun 18 @ 7:35 pm
Well spotted sir, yes i was asking why it didn't work and where else it wouldn't work,
My method just uses vdj values and it's an anomaly that it works with keyboards but not controllers.
i presume the answer would only be useful to about 20 people on the planet.
geposted Fri 08 Jun 18 @ 7:43 pm
Well. The trouble is I dont use the laptop at all usually. And I have a dedicated harwars effects one aptly named flanger so getting this to work would be a good thing for those uses. I do see sometimes it does work. But doest work the 2nd time. Flanger comes on without any gain change.
geposted Fri 08 Jun 18 @ 7:45 pm
Can you try this?
effect_active 'flanger' ? effect_active 'flanger' off & level +15% : effect_active 'flanger' on & level -15%
geposted Fri 08 Jun 18 @ 7:46 pm
This works it takes the channel faders down insted of the gain. Thanks so much.
geposted Sun 10 Jun 18 @ 4:47 pm
i ma guessing these will work for other effects as well when used correctly?
geposted Mon 11 Jun 18 @ 4:08 pm
Yes
geposted Mon 11 Jun 18 @ 4:12 pm
