Topic: Loading karaoke folders
Please explain this to me. I right clicked on the main folder for karaoke and batch after choosing the correct option to load songs into my music folder it started counting up. I left it running all night(I have 1T of karaoke) I woke up 11 hours later to this happening. I don’t understand. This is taking longer then loading my music and karaoke onto my computer. Even that only took 9 hours. HELP!! I have a gig tonight and needed to work with this program a little bit.
Frustrating
geposted Mon 30 Apr 18 @ 1:57 pm
Which option did you choose exactly?
If you selected batch analyze for a big number of tracks that could indeed take a while.
There is no need to wait for it though, you can load and play tracks as you like even if it's not finished.
geposted Mon 30 Apr 18 @ 2:51 pm
Did you select "Add to Search DB" or "Analyze for BPM"?
"Add to Search DB" should only take minutes.
"Analyze for BPM" could take hours and hours; especially with 1TB of music.
geposted Mon 30 Apr 18 @ 10:04 pm
