Topic: Master Effects
Hi,
Can anyone help please. I was looking to set up a slideshow and used to find everything I needed in the master effects. However after a reinstall of windows and VD8.2 I only find the following in the master effects pull down menu:
Backspin, Brakestart, Distortion etc... down to wahwah…. followed by auto start. I used to see sections where slideshow was in there...
Any help would be appreciated to get the old setting back or point to a new way of doing this
Thanks in advance
Andy
geposted Thu 03 May 18 @ 3:15 pm
It's located in master video FX. Enable the video panel in your skin.
geposted Thu 03 May 18 @ 3:22 pm
I think you may be looking in the wrong place
I think you may need to look on the video pane for video effects for things like slideshow
EDIT: kradcliffe was faster :)
geposted Thu 03 May 18 @ 3:24 pm
Thank you both for the quick replies.
I am using default skin.
In the middle pane I see video and under the master output window and then deck a b (side by side) I see transition and video effect.
Is this where you mean or do I need to add something to settings?
I am not sure how to enable panels.
Thanks in advance
geposted Thu 03 May 18 @ 4:54 pm
geposted Thu 03 May 18 @ 5:15 pm
Thank you. All sorted :-)
geposted Thu 03 May 18 @ 5:48 pm
Hi
Can someone please assist me on how to a keyboard shortcut for activating master effects
Thanks
geposted Tue 17 Mar 20 @ 3:04 pm
In its simplest form :
deck master effect_active "Name of The Effect"
geposted Tue 17 Mar 20 @ 3:07 pm
Ciao come si potrebbe dire che l'effetto master funzioni su una manopola eq \?
geposted Tue 21 Jul 20 @ 2:54 pm
