For some reason, cue doesn't work anymore. I move the fader to the right (for example) for deck 2 audio out, then press the cue on deck 1. Checked my headphone cue/main mix and volume, all seem good. But no audio from the cue. Tried chaning the audio out in VDJ to ASIO and to Numark NS7iii 1&2 but nothing works. Even tried resetting Virtual DJ to defaults thinking maybe some setting got changed that I didn't even realized I changed. STILL doesn't work.
Any ideas?
Any ideas?
geposted Sat 05 May 18 @ 12:17 pm
Figured it out. Even though I "reset" VDJ, apparently the settings for the sound card DIDN'T reset. I had the settings incorrect.
geposted Tue 08 May 18 @ 1:52 am
When you reset settings to default you should prompt to restart VDJ and upon restart you should get a detection window for the NS7 III with a "use sound card" button. Clicking on it, it should apply the correct audio setup.
Which of the above didn't happen ?
geposted Tue 08 May 18 @ 5:28 am
I'm having a similar issue. I can only play a cd+g in vdj8 pro on deck one of a four deck system through my mixer...Deck 2 will play but only at the computer. When i first got vdj8 pro i could play all four decks through the mixer. I'm sure my audio settings are off but i'm not sure what i need to change. Video will display on each deck and seems to work fine regardless of which deck i'm on.
geposted Wed 09 May 18 @ 10:52 pm
Post a screenshot of your VirtualDJ Audio setup here
geposted Thu 10 May 18 @ 1:56 am
