Hello,
I'm using VDJ 8.2 (4291) here is my set up:
macbook pro 15
Intel Core i7 2.3GHz
16 GB 1600 MHz DDR3
YOSEMITE
Intel HD Graphics 4000 1024 MB
I mix with turntables or Cdj 2000 with timecode and my mixer is a pioneer Djm S9.
When using VDJ, the software can freeze at any time and I have no sound.
To solve the problem, I must either go to the VDJ settings and choose the sound card of the Djm S9 again or restart the software.
This is very embarrassing when it happens in the middle of a party.
I noticed that if I touch the USB cable this phenomenon can happen.
I deduce that it comes from the USB connection between the computer and the Djm S9.
For now I plan to test an Oyaide class B cable because until now I used the cable provided with the S9.
Have you ever encountered this problem? What can you suggest me to solve that problem.
Thank you for your help and anwers
macbook pro 15
16 GB 1600 MHz DDR3
YOSEMITE
geposted Thu 10 May 18 @ 10:12 pm
