Forum: Addons
Addons comments
Topic: Equalizer 30
geposted Thu 17 May 18 @ 8:29 pm
what's a good default setting ?
Does anyone have any settings they can share ?
Thanks.
geposted Mon 03 Sep 18 @ 10:43 pm
It's an equalizer, so it's usually used to correct the sound.
It will therefore completely depend on the music you play, the sound system you use, the riom acoustics and the wanted sound what a good setting is.
geposted Tue 04 Sep 18 @ 5:42 am
muy bueno pero aun esperamos mas. similar a este efecto deberia existir uno q divida en 2 salidas mono y q en cada linea se aplique cortes de frecuencia para bajo y medio brillo la siguiente linea.. gracias en todo caso. es de mucha ayuda..
geposted Tue 11 Dec 18 @ 7:17 pm
0rafa0PRO InfinityMember since 2012
equalizer for macintosh systems? where is it?
geposted Wed 12 Jun 19 @ 10:26 pm
gd77laPRO InfinityMember since 2015
Hello I was using EQ 10 with Mac but it no longer shows up. Is there a way to get this to work with Virtual DJ 8?
geposted Sat 15 Jun 19 @ 7:11 pm
Please update for 64bit... Used with 32bit VDJ 2018 to increase bass a little, but can't find it in VDJ 2020
geposted Sat 28 Sep 19 @ 10:37 am
Why can't you just turn up the 'low' EQ on the mixer? Or you could use EQ10. Or you could use a VST plugin.
geposted Sat 28 Sep 19 @ 10:55 am
I run EQ30 on master in auto-start to increase bass permanently.
geposted Sat 28 Sep 19 @ 12:27 pm
