XIVAN MAR. wrote :
Hello, my question is:
How can I map the preview output of a sampler to channel 4.
For example, I launch a sampler where I have a 1/4 loop snare roll and be able to preview channel 3 to see if when it is launched it is square with the song that is playing, but to launch it again until it is square.
Like when 2 songs are mixed that one you are listening to through the preview before uploading the channel.
In this case it would be to launch the sampler with pad 1, do the preview and if it is well squared with the song, raise the sampler_volume_master.
i have mapped “pfl” button of my controller in this mode (i usually use deck 3 and channel 3 for sampler):
pfl: action_deck 3 ? pad_page ‘sampler’ ? sampler_output ‘headphones’ ? deck 3 sampler_output : sampler_output ‘headphones’ : deck 3 pfl : pfl
in this mode if you have in deck 3 pad_page ‘sampler’ you have pfl about sampler...for other pad_page in deck 3 you have normal pfl...in other decks you have normal pfl
geposted Sun 21 Feb 21 @ 2:19 pm
hi, i have this question: in my monitor reloop touch i have add battery % with script “get_battery” and work well, but which is script for blink battery % under 20%?? thanks a lot!!
geposted Sun 21 Feb 21 @ 2:24 pm
Perfect is what I was looking for.
But how do you have the sampler setup in deck 3?
I use the sampler in master output. How do I configure it for deck 3?
geposted Sun 21 Feb 21 @ 3:31 pm
@mg_1978
"blink battery % under 20%??"
didn't you try
get_battery & param_smaller 20% ? blink
@XIVAN MAR.
there is only one sampler in VDJ
you can force its output to deck 3
or select deck (or remove) using
sampler_output popup
didn't you try
@XIVAN MAR.
geposted Sun 21 Feb 21 @ 3:48 pm
Thanks.
I'll try. 👌🏻👌🏻👌🏻
I'll try. 👌🏻👌🏻👌🏻
Nicotux wrote :
@mg_1978
didn't you try
@XIVAN MAR.
didn't you try
@XIVAN MAR.
geposted Sun 21 Feb 21 @ 3:55 pm
@XIVAN MAR
As Nicotux says use the Sampler popup to select Deck 3
described in the manual
http://www.virtualdj.com/manuals/virtualdj/interface/browser/sideview/sampler/index.html
geposted Sun 21 Feb 21 @ 3:57 pm
I have mapped the pfl to deck 4, because I would like to use this deck.
But the option to remove the sound through deck 4 does not come out or I have no idea of making deck 4 be heard.
IIDEEJAYII wrote :
@XIVAN MAR
geposted Sun 21 Feb 21 @ 4:18 pm
..because you can use eq, gain and filter fx of the deck 3 or channel 3 in your controller....and effects of deck 3 😉
geposted Sun 21 Feb 21 @ 6:55 pm
The problem is that it is not configured to output the sound of the sampler in deck 3.
I don't know where I have to map deck 3 sampler_output
I have a knob mapped to sampler_volume_master, but that doesn't get the sound out of me for a deck.
geposted Sun 21 Feb 21 @ 7:16 pm
no need to quote quoted just written messages ^^^
you can map deck 3 sampler_output to oninit
geposted Sun 21 Feb 21 @ 7:22 pm
by the way this revealed a bug in site : quoted messages from home user are funny (not allowed in theory, bug make them work)
only nested one are reported making think initial quoted was rewritten ^^
geposted Sun 21 Feb 21 @ 7:26 pm
@ Xivar
which is your controller? have 4 decks controller or only 2 decks? you can map pfl (prelisten button about deck) as I wrote you above and you have deck 3 sampler output with pfl button :)
geposted Sun 21 Feb 21 @ 8:16 pm
I just got it.
I finally get the sampler out of deck 4 and can preview it.
Thanks to NICOTUX and MG_1978.
My controller is the 4-deck XDJ-XZ.
I already got it.
Thanks. MG_1978 😊😊😊
I already got it.
Thanks. MG_1978 😊😊😊
mg_1978 wrote :
@ Xivar
geposted Sun 21 Feb 21 @ 8:36 pm
hi. i have this question: if i map button: browser_move +1 (i use this in sideview 'sampler') why i can't see the change of position about sampler in pad_page 'sampler' ? for example i move sampler 1 from position 1 to 4...but in sampler pad i can't see changing :( but if with mouse i do the same thing....yes....sampler 1 change position in pad_page 'sampler'....don't understand why :(
geposted Tue 23 Feb 21 @ 6:55 pm
Just because sampler is not a file browser
it have its own selection command
sampler_select +1
sampler_select -1
(does not seems to show selection in grid mode)
sampler_select +1
sampler_select -1
geposted Tue 23 Feb 21 @ 7:13 pm
sampler_select +1
sampler_select -1
sampler_select +1
sampler_select -1
mmmm sampler_select is only for selection about sampler...but doesn't move the sampler...for move sampler (from position 1 to position 4 for example) what i add in sampler_select??
geposted Tue 23 Feb 21 @ 8:26 pm
not clear,
do you want to move a sample from slot 1 to slot 4 ?
geposted Tue 23 Feb 21 @ 10:01 pm
Nicotux wrote :
not clear,
oh yess...could make it with button mapping???
geposted Tue 23 Feb 21 @ 10:16 pm
