Topic: Script School - Page: 24.2
@Locodog: thanks to your help I found the right script:
not quite what I had, but good stuff, In future post the actual script & not a screenshot [sideways camera shot, eugh], makes it easier for everybody.
effect_slider 'flanger' 1 0 & padfx 'flanger' smart_pressed & repeat_start 'lic' 50ms 10 & effect_active 'flanger' on ? effect_slider 'flanger' 1 +8% : repeat_stop 'lic'
So I figured out how to have a dial pan between stems and on button press invert a given stem:
First, the pan:
set $fv & param_smaller 0.5 ? set $rv & deck right stem 'vocal' & set $lv 0.5 & deck left stem 'vocal' 0.5 : param_invert & set $lv & deck left stem 'vocal' & set $rv 0.5 & deck right stem 'vocal' 0.5
Second, the button:
set $temp '$lv' & set $lv '$rv' & set $rv '$temp' & get_var $rv & param_cast & deck right stem 'vocal' & get_var $lv & param_cast & deck left stem 'vocal' & get_var $fv & param_invert & set $fv
I use the $fv variable to keep the led dial lights synced
hi Is it possible to activate the B-JUMP function with the MOVE button
When I work with Virtual DJ 8
Together with the S4 MK3 controller?
Hey guys, Awesome resources here. I know the very basics of scripting, but i can't figure out how to toggle a specific effect over a period of beats. The main thing I am trying to do is have an effect or video effect toggle every 16 beats. So basically if I enable the script the specified effect will toggle on & off every 16 beats. I'm mainly trying to do negative effect on the master deck. Any advice would be greatly appreciated.
@jason.a.prince
timed and freehand start
deck master repeat_start_instant negToggle ? on & repeat_stop negToggle : off & repeat_start_instant negToggle 16bt & effect_active negative -1
driven by masterdeck beat position
deck master repeat_start_instant 'negtoggle' ? on & deck master repeat_stop 'negtoggle' & effect_active 'negative' off : repeat_start_instant 'negtoggle' 30ms -1 & param_bigger `deck master get_beat_bar 32` 0.5 ? effect_active 'negative' off : effect_active 'negative' on
Is it possible to switch of the Logo (Pro Infinity) by script while a Karaoke flagged track is playing and let it return when the Karaoke track ended?
I plan to put a QR code to my request website as the logo.
As i have karaoke video's with the lyrics at different heights the logo/QR code is over the lyrics.
LOCODOG, You my friend are a legend. Thank you so much.
What about a script that randomly toggles a specific effect but with a slider to choose how often. E.G Have blur random toggle on master video, but only comes on for a second or two every so many beats or seconds?
more suited to a virtualfx.
For some action-cues:
How can I query the deck in which the song is loaded?
(just don´t know the syntax)
Thanks for help
get_deck returns a number,
action_deck can be queried against a number [or side]
If I want to automatically jump from cue2 to cue3, but only when the song is loaded in deck 1?
the following line doesn´t make it:
set "$DELO" get_deck & var "$DELO" 1 ? goto_cue 3 : nothing
missed the backticks to set the var to a script value
set "$DELO" `get_deck` & var "$DELO" 1 ? goto_cue 3 : nothing
variables probably isn't the best way, a direct query of get_deck needs no cleaning up
param_equal get_deck 1 ? goto_cue 3 : nothing
That's it! Thanks for the quick answer.
I have some problem with a script.
I have a button scripted with a cut effect. On top the cut effect i want a reverb.
The button works but sometime the reverb is before the cut and not after.
How can i prevent that?
effect_active "cut" ON while_pressed & effect_beats "cut" 0.5bt & effect_slider "cut" 1 70% & effect_active "reverb" ON while_pressed
I think you're getting the bug when pressing fast and also have trailing stop on the reverb effect, turn trailing off as a part of your script, that should solve it
effect_button 'reverb' 2 0 & effect_active "cut" ON while_pressed & effect_beats "cut" 0.5bt & effect_slider "cut" 1 70% & effect_active "reverb" ON while_pressed
Thanks! Works great.
More script questions (trying to learn but its hard):
Klausmogensen script "Noice effect as a sweep". I want it to work only when the button is pressed.
I have change it and it works and the effect stops when i release the button, but the sweep is continues in the background. Cant figure out how to prevent it.
effect_slider 'noise' 1 20% && effect_slider 'noise' 2 20% && effect_active 'noise' 1 while_pressed && repeat_start 'wait' 300ms & effect_slider 'noise' 1 +1% & effect_slider 'noise' 2 +3% & effect_slider 'noise' 1 50% ? effect_active 'noise' 0 & repeat_stop 'wait'
Probably better suited to a virtualfx if you're using a windows machine
45%
