Hmmm The new script doesn't seem to work.
The text isn't changing
geposted Mon 05 Dec 22 @ 12:53 pm
sorry. I'll check it
*edit, found it an errant quote and used a local var instead of a global var.
I added a place near the start so when it is running you can change between countdown showing and a generic message,
plus at the end I left a space to have a message after happy new year, [but the effect is turned off then and text effect use is back to normal].
when it's initialising it takes a couple of seconds to brute force the time [it's garbled for a few seconds], so it just says "COUNTDOWN" until it's ready to run smoothly.
I could add stuff to this for days but really it's a case by case, for what people need
geposted Mon 05 Dec 22 @ 1:09 pm
just consider this a visual count down, it can do stuff for automation like show the counter for a minute every 15 minutes, probably some radio applications too, but the real event scheduler is a bit easier.
geposted Mon 05 Dec 22 @ 2:24 pm
True, and thank you
I've now replaced the downloadable script in the video
geposted Mon 05 Dec 22 @ 2:49 pm
Cool
I've updated the script linked in the video
geposted Mon 05 Dec 22 @ 4:17 pm
Hi
I have always used the "comment" field for remix info because originally VDJ didn't have a 'remix' field to use & I was happy to continue in that vein, however now I am using online content I need the remix field visible.
I have worked out that
browsed_song 'remix' `get_browsed_song 'comment'`
will successfully copy the comment over to the remix field but this only works 1 file at a time.
Is there a quick way I can change, either selected files or all files in a folder, in 1 go.
Basically I need a script to recurse through the list of files & copy the comment field to the remix field.
Any pointers would be appreciated. If this has been covered elsewhere I apologise.
Thanks
Thanks
geposted Mon 05 Dec 22 @ 7:20 pm
That would be a repeat_start script [a.k.a. rsi, repeat_start_instant]
probably best if you start out of a filter [advanced] to get all files, something like
filter
button script
or this to also clear the comment field after it copies over
either will take a little while, it processes about 2000 tracks a minute
filter
Length > 60 and Comment is not ""
button script
browser_scroll 'top' & repeat_start_instant scroller 25ms & browsed_song 'remix' `get_browsed_song 'comment'` & browser_scroll 'bottom' ? repeat_stop scroller : browser_scroll +1
browser_scroll 'top' & repeat_start_instant scroller 25ms & browsed_song 'remix' `get_browsed_song 'comment'` & browsed_song 'comment' "" & browser_scroll 'bottom' ? repeat_stop scroller : browser_scroll +1
geposted Tue 06 Dec 22 @ 4:57 am
There are some people saying it just stays on COUNTDOWN when they try the script
Not sure why...
Not sure why...
geposted Tue 06 Dec 22 @ 5:27 am
Found it, 12 hour clock users. I'll make the changes needed, and post here when changed
*edit changed*
*edit changed*
geposted Tue 06 Dec 22 @ 5:41 am
Hi, is there a simpler way to create save Stems with a custom Button.
The Stems should be save from the loaded Song in the deck and not from the browser.
The second. Is there a way to visible "has prepared Stems" like Browser Color Rules, for the loaded Song?
browser_window 'songs' & wait 150ms & search_add `deck left get_filepath` & browser_scroll +1 & browser_scroll -1 & wait 150ms & virtualfolder_add 'stems' & wait 150ms & search_delete & goto_last_folder
geposted Wed 07 Dec 22 @ 10:41 am
has_stems "2.0"
isn't a filter yet, but they are all filtered in the the prep'd folder.
not sure about adding.
geposted Wed 07 Dec 22 @ 1:20 pm
has_stems '2.0' is always true when RealtimeSeperation enabled.
I need a true when a prepared stem is saved.
geposted Wed 07 Dec 22 @ 2:11 pm
how to assign a button so that when it is activated, the filter works as filter_selectcolorfx 'pitch', but only for voice?
geposted Wed 07 Dec 22 @ 5:52 pm
effect_stems 'vocal' on ? effect_stems 'vocal' off : effect_stems 'vocal' on & filter_selectcolorfx 'pitch'
something like that
geposted Wed 07 Dec 22 @ 6:34 pm
If you are asking if it is possible to change/set a color for tracks, that have prepared stems?
This can be done with a color rule: Prepared Stems = 1
geposted Wed 07 Dec 22 @ 7:19 pm
button script
button script
Thanks for that. I figured to either us a filter or just smaller folders to make it easier, also going to disable automatic writing of mp3 tags before hand otherwise my backups will take forever.
I'm still trying to get my head around repeat from your previous lessons but this example seems really straight forward and easy to understand & edit if I needed something similar.
PS. also added ' browser_window "songs" & ' to the beginning of the script cause I will forget to click in the songs windows 1st due to being hopeless.
geposted Fri 09 Dec 22 @ 7:40 pm
Hi.
We decided here whether the script can count the number of characters in the string.
It took me a while, but I understood him.
Can the script be modified to detect if the string is longer, shorter than 25 characters? Nothing comes to my mind.
edit
Can't write in a shorter script?
param_equal `get_var a` `get_var a & param_cast 'text' 1` ? SIZE OF 1 :
param_equal `get_var a` `get_var a & param_cast 'text' 2` ? SIZE OF 2 : ......
edit
set_var 'a' "12345678901234567890123456" &
(param_equal `get_var a` `get_var a & param_cast 'text' 1` ? set 'length' 1 :
param_equal `get_var a` `get_var a & param_cast 'text' 2` ? set 'length' 2 :
param_equal `get_var a` `get_var a & param_cast 'text' 3` ? set 'length' 3 :
param_equal `get_var a` `get_var a & param_cast 'text' 4` ? set 'length' 4 :
param_equal `get_var a` `get_var a & param_cast 'text' 5` ? set 'length' 5 :
param_equal `get_var a` `get_var a & param_cast 'text' 6` ? set 'length' 6 :
param_equal `get_var a` `get_var a & param_cast 'text' 7` ? set 'length' 7 :
param_equal `get_var a` `get_var a & param_cast 'text' 8` ? set 'length' 8 :
param_equal `get_var a` `get_var a & param_cast 'text' 9` ? set 'length' 9 :
param_equal `get_var a` `get_var a & param_cast 'text' 10` ? set 'length' 10 :
param_equal `get_var a` `get_var a & param_cast 'text' 11` ? set 'length' 11 :
param_equal `get_var a` `get_var a & param_cast 'text' 12` ? set 'length' 12 :
param_equal `get_var a` `get_var a & param_cast 'text' 13` ? set 'length' 13 :
param_equal `get_var a` `get_var a & param_cast 'text' 14` ? set 'length' 14 :
param_equal `get_var a` `get_var a & param_cast 'text' 15` ? set 'length' 15 :
param_equal `get_var a` `get_var a & param_cast 'text' 16` ? set 'length' 16 :
param_equal `get_var a` `get_var a & param_cast 'text' 17` ? set 'length' 17 :
param_equal `get_var a` `get_var a & param_cast 'text' 18` ? set 'length' 18 :
param_equal `get_var a` `get_var a & param_cast 'text' 19` ? set 'length' 19 :
param_equal `get_var a` `get_var a & param_cast 'text' 20` ? set 'length' 20 :
param_equal `get_var a` `get_var a & param_cast 'text' 21` ? set 'length' 21 :
param_equal `get_var a` `get_var a & param_cast 'text' 22` ? set 'length' 22 :
param_equal `get_var a` `get_var a & param_cast 'text' 23` ? set 'length' 23 :
param_equal `get_var a` `get_var a & param_cast 'text' 24` ? set 'length' 24 :
param_equal `get_var a` `get_var a & param_cast 'text' 25` ? set 'length' 25 :
set 'length' 26) &
var_smaller 'length' 25 ? set_var 'copmp' "smaller" :
var_equal 'length' 25 ? set_var 'copmp' "equal" :
var_greater 'length' 25 ? set_var 'copmp' "greater"
geposted Fri 09 Dec 22 @ 10:47 pm
start at 24 if thats all you need.
geposted Sat 10 Dec 22 @ 7:30 am
Yes. You are right to use the property "24". Thanks
param_equal `get_var a` `get_var a & param_cast 'text' 24` ? set_var 'comp' "smaller" :
param_equal `get_var a` `get_var a & param_cast 'text' 25` ? set_var 'comp' "equal" :
set_var 'comp' "greater"
geposted Sat 10 Dec 22 @ 11:50 am
Is there a script that would let me continue my track playing from the point that a loop started at when exiting, instead of continuing from the end of the loop. I would like to jump back to the point the loop started and go from there. why I hear you ask.
so if I have a track that has no decent intro to mix with, I could loop the first 1 or 2 bars and use stems to remove the vocals and melody, to get just a rhythm loop, and then exit the loop and re-enable the vocal and melody stems and jump back to the start point of the now exited loop and continue playing the track with the full vocal and melody.
hope that made sense.
M.
geposted Thu 15 Dec 22 @ 11:27 am
