Topic: Script School - Page: 31.9
Hi, is there a simpler way to create save Stems with a custom Button.
The Stems should be save from the loaded Song in the deck and not from the browser.
browser_window 'songs' & wait 150ms & search_add `deck left get_filepath` & browser_scroll +1 & browser_scroll -1 & wait 150ms & virtualfolder_add 'stems' & wait 150ms & search_delete & goto_last_folder
The second. Is there a way to visible "has prepared Stems" like Browser Color Rules, for the loaded Song?
has_stems "2.0"
isn't a filter yet, but they are all filtered in the the prep'd folder.
not sure about adding.
has_stems '2.0' is always true when RealtimeSeperation enabled.
I need a true when a prepared stem is saved.
how to assign a button so that when it is activated, the filter works as filter_selectcolorfx 'pitch', but only for voice?
effect_stems 'vocal' on ? effect_stems 'vocal' off : effect_stems 'vocal' on & filter_selectcolorfx 'pitch'
something like that
If you are asking if it is possible to change/set a color for tracks, that have prepared stems?
This can be done with a color rule: Prepared Stems = 1
locodog wrote :
That would be a repeat_start script [a.k.a. rsi, repeat_start_instant]
button script
browser_scroll 'top' & repeat_start_instant scroller 25ms & browsed_song 'remix' `get_browsed_song 'comment'` & browser_scroll 'bottom' ? repeat_stop scroller : browser_scroll +1
either will take a little while, it processes about 2000 tracks a minute
Thanks for that. I figured to either us a filter or just smaller folders to make it easier, also going to disable automatic writing of mp3 tags before hand otherwise my backups will take forever.
I'm still trying to get my head around repeat from your previous lessons but this example seems really straight forward and easy to understand & edit if I needed something similar.
PS. also added ' browser_window "songs" & ' to the beginning of the script cause I will forget to click in the songs windows 1st due to being hopeless.
Hi.
We decided here whether the script can count the number of characters in the string.
It took me a while, but I understood him.
param_equal `get_var a` `get_var a & param_cast 'text' 1` ? SIZE OF 1 :
param_equal `get_var a` `get_var a & param_cast 'text' 2` ? SIZE OF 2 : ......
Can the script be modified to detect if the string is longer, shorter than 25 characters? Nothing comes to my mind.
edit
Can't write in a shorter script?
set_var 'a' "12345678901234567890123456" &
(param_equal `get_var a` `get_var a & param_cast 'text' 1` ? set 'length' 1 :
param_equal `get_var a` `get_var a & param_cast 'text' 2` ? set 'length' 2 :
param_equal `get_var a` `get_var a & param_cast 'text' 3` ? set 'length' 3 :
param_equal `get_var a` `get_var a & param_cast 'text' 4` ? set 'length' 4 :
param_equal `get_var a` `get_var a & param_cast 'text' 5` ? set 'length' 5 :
param_equal `get_var a` `get_var a & param_cast 'text' 6` ? set 'length' 6 :
param_equal `get_var a` `get_var a & param_cast 'text' 7` ? set 'length' 7 :
param_equal `get_var a` `get_var a & param_cast 'text' 8` ? set 'length' 8 :
param_equal `get_var a` `get_var a & param_cast 'text' 9` ? set 'length' 9 :
param_equal `get_var a` `get_var a & param_cast 'text' 10` ? set 'length' 10 :
param_equal `get_var a` `get_var a & param_cast 'text' 11` ? set 'length' 11 :
param_equal `get_var a` `get_var a & param_cast 'text' 12` ? set 'length' 12 :
param_equal `get_var a` `get_var a & param_cast 'text' 13` ? set 'length' 13 :
param_equal `get_var a` `get_var a & param_cast 'text' 14` ? set 'length' 14 :
param_equal `get_var a` `get_var a & param_cast 'text' 15` ? set 'length' 15 :
param_equal `get_var a` `get_var a & param_cast 'text' 16` ? set 'length' 16 :
param_equal `get_var a` `get_var a & param_cast 'text' 17` ? set 'length' 17 :
param_equal `get_var a` `get_var a & param_cast 'text' 18` ? set 'length' 18 :
param_equal `get_var a` `get_var a & param_cast 'text' 19` ? set 'length' 19 :
param_equal `get_var a` `get_var a & param_cast 'text' 20` ? set 'length' 20 :
param_equal `get_var a` `get_var a & param_cast 'text' 21` ? set 'length' 21 :
param_equal `get_var a` `get_var a & param_cast 'text' 22` ? set 'length' 22 :
param_equal `get_var a` `get_var a & param_cast 'text' 23` ? set 'length' 23 :
param_equal `get_var a` `get_var a & param_cast 'text' 24` ? set 'length' 24 :
param_equal `get_var a` `get_var a & param_cast 'text' 25` ? set 'length' 25 :
set 'length' 26) &
var_smaller 'length' 25 ? set_var 'copmp' "smaller" :
var_equal 'length' 25 ? set_var 'copmp' "equal" :
var_greater 'length' 25 ? set_var 'copmp' "greater"
start at 24 if thats all you need.
Yes. You are right to use the property "24". Thanks
param_equal `get_var a` `get_var a & param_cast 'text' 24` ? set_var 'comp' "smaller" :
param_equal `get_var a` `get_var a & param_cast 'text' 25` ? set_var 'comp' "equal" :
set_var 'comp' "greater"
Is there a script that would let me continue my track playing from the point that a loop started at when exiting, instead of continuing from the end of the loop. I would like to jump back to the point the loop started and go from there. why I hear you ask.
so if I have a track that has no decent intro to mix with, I could loop the first 1 or 2 bars and use stems to remove the vocals and melody, to get just a rhythm loop, and then exit the loop and re-enable the vocal and melody stems and jump back to the start point of the now exited loop and continue playing the track with the full vocal and melody.
hope that made sense.
M.
reloop & loop off
so is there now a way of waiting till the end of the current loop before doing the reloop. for example if i press the button to do this and the current loop is on beat 3 for example, I dont want it to reloop immediately, but wait until it is at the end of the current loop and is about to restart the loop.
so far I have
var $intromode 1 ? reloop & only_stem "melody" & only_stem "vocal" & loop off & set $intromode 0 : loop 4 & mute_stem "Melody" & mute_stem "vocal" & set $intromode 1
if waiting for end of loop to reloop, just let it loop and not use reloop. Use a rsi to monitor and save inLoop position, if current is smaller than saved then the loop has just restarted and your switches can be reset.
Locodog.. wouldn't this be a great use for your RoutineSP addon?
https://www.virtualdj.com/forums/233820/Addons/routineSP.html?search=routinesp&page=1
Update: Opps.... I see needs vocal stems removed and added back. Then may not be best use
Or could use RoutineSP and only need to do the stems manipulation.
I have a custom button that record a shader for 10 sec and after that it changes to the next shader and then wait 3 sec.
I want to repeat this until the button is pressed again. Is it possible?
record on & wait 10000ms & record off & effect_string ”audioonlyvisualation” 1 +1 & wait 3000ms
deck master repeat_start_instant 'rsiShaderRecord' ? on & record off & deck master repeat_stop 'rsiShaderRecord' : off & record on & deck master repeat_start_instant 'rsiShaderRecord' 13000ms -1 & (  record ? : record on ) & wait 10000ms & record off & effect_string audioonlyvisualisation 1 +1
typo in your visualisation that copied thru but seems there's something in the previous script, it doesn't like to set up the recording for some reason.
use this instead, first shader might not record, but there after will
Ah, now it works. Thank you !!!
Hi! Tell me how to write the script correctly: (deck right filter_selectcolorfx 'noise' smart_pressed)
it should work like this: when you turn the filter knob and hold the button with this script, the noise effect sounds, if you release the button, the noise effect does not sound.
Look at filter_activate
60%
