Vocal FX Pad Mode Editing :
Hi Guys, I need your help editing a pad page that i find very useful in vdj. Its the Vocal FX pad mode by Rune(DJ In Norway). i want help editing the pad modes so they can be toggled on and off instead of pushed down and release action. and if possible also with LED feedback so you know its on. The pad i am most interested in editing is the LOOPCHOP. Thanks in advance .
P.S : I sent this message initially as a DM to @locodog but it seems he is a bit occupied so decided to put it on here. Thanks
FYI : Just In Case Anyone on here is willing to convert/write scripts for a VDJ Add-on called Sticky for Mac Users, please let me know so i can contact you for help. Thanks
geposted Mon 02 Jan 23 @ 2:35 pm
After bring it up to date
then change down query to a var query and include 2 toggles of the var
I'm going to have to start charging for this
down ?
on & set 'VoxFXcount' `var 'VoxFXcount' ?
get_var "VoxFXcount" & param_add 1 : get_text '1' & param_cast val` & set 'voxLoopCycle' 0 & effect_stems 'vocal' on & repeat_stop 'voxRoller2' & quantize_loop on & padfx 'loop roll' 0.9 0.75 & wait 1bt 1 & repeat_start 'voxRoller' 1bt & effect_slider 'loop roll' 2 -20% & cycle 'voxLoopCounter' 2 & var 'voxLoopCounter' 0 ?
repeat_stop 'voxRoller'& repeat_start 'voxRoller2' 1bt & effect_slider 'loop roll' 1 -15% & cycle 'voxLoopCycle' 6 & var 'voxLoopCycle' 0 ?
repeat_stop 'voxRoller2' :
nothing :
nothing :
off & repeat_stop 'voxRoller2' & effect_active 'loop roll' off & get_var "VoxFXcount" & param_equal 1 ?
effect_stems 'vocal' off & set 'VoxFXcount' `get_var "VoxFXcount" & param_add -1` :
var voiceThing 0 ?
on & toggle voiceThing & set 'VoxFXcount' `var 'VoxFXcount' ?
nothing :
nothing :
off & toggle voiceThing & repeat_stop 'voxRoller2' & effect_active 'loop roll' off & get_var "VoxFXcount" & param_equal 1 ?
effect_stems 'vocal' off & set 'VoxFXcount' `get_var "VoxFXcount" & param_add -1` : set 'VoxFXcount' `get_var "VoxFXcount" & param_add -1`
geposted Mon 02 Jan 23 @ 3:16 pm
@Ziglar
I remember the code now to approximate sticky just with script, but I just don't like it, I don't want to introduce it because it's backwards to how sticky actually works and it would cause problems if sticky ever did get a port to mac.
geposted Mon 02 Jan 23 @ 6:04 pm
locodog wrote :
Ok I do understand. I just Hope it gets ported sooner than later. @Ziglar
geposted Mon 02 Jan 23 @ 7:59 pm
down ?
nothing :
nothing :
var voiceThing 0 ?
nothing :
nothing :
Thank you for your help again. I will input it and give you feedback. As for charging for it, please check your dm. i am willing to offer something for your help always. I just don't have paypal. If you happen to get another means where i can support,please let me know. Thanks
geposted Mon 02 Jan 23 @ 8:01 pm
Here a little Script to add a manually input Dialog for set Pitch to a specific BPM Value. :)
set set_bpm `get_bpm` & set_var_dialog set_bpm BPM &
repeat_start 'bpm_change' 250ms 240 &
param_equal '`get_var set_bpm`' '`get_bpm`' ? nothing :
get_var set_bpm & param_cast 'beats' & pitch & repeat_stop 'bpm_change'
geposted Mon 09 Jan 23 @ 11:05 am
@DennYo Beats nice, I really like set_var_dialog from a makers perspective.
it's like a little command line
the part the calls the dialog is just waiting for the var change, all the user has to do is press the button and the dialog can give hand holding instructions
geposted Mon 09 Jan 23 @ 12:20 pm
Hey Script-Pros,
is it possible to have "controllerTakeoverMode"="gradual" for gain knob only. Is it possible to read the controller knob position of a knob or slider using VDJ script, when it isn't synchronous with the software position. All the scripts seam to report the software-position.
Thx in advance!
Cheers
Jochen
Thx in advance!
Cheers
Jochen
geposted Tue 10 Jan 23 @ 9:09 pm
@EGR if every dial command changed the setting and changed back, maybe.
setting controllerTakeoverMode "instant" & level & setting controllerTakeoverMode "gradual"
geposted Wed 11 Jan 23 @ 4:11 am
@LOCODOG,
that is a very good idea and may do the trick. Will check it in the evening, when I'm back home.
I said it may times and have to do it again.
This community is awesome. Thx a lot for your quick and helpful answers!
Cheers
Jochen
Cheers
Jochen
geposted Wed 11 Jan 23 @ 7:04 am
Hey LocoDog,
checkt your idea and it worked! Thx a lot!
Everything is on "pickup" except gain:
Cheers
Jochen
setting controllerTakeoverMode "gradual" & gain & setting controllerTakeoverMode "pickup"
Cheers
Jochen
geposted Thu 12 Jan 23 @ 12:11 pm
How to add strings [append a tag example]
quick one, save the text I want to add,
set a temp var, adding the thing I want to add to the thing I want to add to
grab the var, cast it as text, cast it to the thing I want to change
or even briefer
even briefer still, and in the order that doesn't hurt my primitive brain
Without a variable
set_var string " text I want to add" &
set temp `param_add 'get_var string' 'get_browsed_song comment'` &
get_var temp & param_cast 'text' & browsed_song "comment"
or even briefer
get_text "`param_add 'get_var string' 'get_browsed_song comment'`" &
param_cast & browsed_song comment
get_text "`get_browsed_song comment``get_var string`" &
Without a variable
get_text "`get_browsed_song comment` myTextToAdd" & param_cast & browsed_song comment
geposted Mon 23 Jan 23 @ 2:19 am
locodog wrote :
How to add strings [append a tag example] ....
Thats a very usefull script... Thanks for sharing ... i love it. <3
geposted Mon 23 Jan 23 @ 11:22 am
Hey everybody,
I try to create a day-theme for the Prime GO.
Everythings looks great except the bowser list.
How can I change the colors of the browser list?
Here are the elements the default theme is using:
How can I change colors in the design-tag?
Thx Jochen
<define class="primebrowser">
<font fontsize="24"/>
<fontheader fontsize="22"/>
<fontsearch fontsize="16"/>
</define>
<filelist class="primebrowser" headerheight="[LINEHEIGHT]" lineheight="[LINEHEIGHT]">
<pos x="+0" y="+50"/>
<size width="[BRWIDTH]" height="[BRHEIGHT]-50"/>
</filelist>
Thx Jochen
geposted Sun 05 Feb 23 @ 3:14 pm
@EGR a question better suited for the skins forum.
geposted Sun 05 Feb 23 @ 3:19 pm
Electronic Green Room wrote :
Hey everybody,
I try to create a day-theme for the Prime GO. ....
add in the <define class="primebrowser"...> the COLOR children.
https://www.virtualdj.com/wiki/Skin%20Browser.html
When you need mor help please post in the Skin Forum.
geposted Sun 05 Feb 23 @ 3:35 pm
hello, help me assign a button so that when you turn it on, the effect 'reverb' and stems fx 'vocal' are activated, and when you press the button again, the effect 'reverb' and stems fx 'vocal' disconnected.
something like this, but it doesn't work: deck right effect_active 'reverb' & effect_stems 'vocal' on : effect_stems off
geposted Mon 27 Feb 23 @ 7:02 pm
happened!!! it works: deck right effect_active 'reverb' ? effect_stems 'vocal' on : effect_stems off
now the question is how to register so that the button blinks when the effect is on and burns when it is off?
I used to have this: deck right effect_active 'reverb' ? blink 300ms ? color 'magenta' : off : color 'darkmagenta' now it doesn't work.
geposted Wed 01 Mar 23 @ 11:44 am
@DJElementDJ
A maybe better script for the button may be:
And your above script for the LED will work as posted.
deck right effect_active 'reverb' ? effect_stems 'vocal' off & effect_active 'reverb' off : effect_stems 'vocal' on & effect_active 'reverb' on
geposted Wed 01 Mar 23 @ 5:46 pm
or even briefer
or even briefer
get_text "`browsed_song comment``get_var string`" &
Love the scripting, and cannot get the 3rd script to append, instead it replaces, current comment with the " text I want to add".
Its the get_text "`browsed_song comment``get_var string`" that is not behaving.
Has something changed since the original post that broke it?
geposted Wed 01 Mar 23 @ 5:58 pm
