Topic: Script School - Page: 34.8
locodog wrote :
crossfader_disable ? crossfader_hamster on & key_lock off & crossfader_disable off : key_lock on & crossfader_disable on
something like that?
I will try it out and see if it works. Thank you so much.
hello guys, how to write a script so that after the cue point every 500ms, the volume of the vocal decreases gradually every 500ms and stops at 10%
all i could think of was: stem 'vocal' 500ms 10%
but it doesn't work.
you need to call a repeat_start, that rs will be querying param_smaller `stem vocal` 10% ? if 10% is smaller reduce the stem some : if 10% isn't smaller then we got to where we need to be and we can repeat_stop
Should be enough there for you to go on. I've told you pretty much everything without giving you the full script, repeat_start scripts I've covered.
Oh, LOKODOG, it's hard for me. This is what I was able to write after reading your answer: repeat_start? param_smaller `stem vocal` 10% ? 500ms : Repeat_stop
But this, of course, is nonsense.
if possible, then write me a full script, if there is no time, then I will not be offended.
goal : when the track is playing and gets to the cue point, then the stem vocal for 4 seconds is slowly removed to 10%
It's hard for everybody until they practice, you almost had it, go to the first post of this thread, there you will find an index for topics I've covered.
Read the post called "repeat_start, repeat_stop" it is linked.
I didn't write all these pages for myself, I wrote them for people to learn, and I've become bored of repeating myself.
hi at all; is there a script in Vdj verbs list to lock all deck functions about deck 1 and deck 3 (or deck 2 and 4 in rightdeck)…..like “dual deck function” in Pioneer controller….thanks!
First off apologies if I have asked this question before.
I know for custom buttons if you use `<script>` in the button name, it can be dynamic to represent a value, but can this be done in the skin for normal buttons.
I am trying to modify my skin to add a button that will cycle through the stem types, in my custom button i can use a button name of `setting 'stemsRealtimeSeparation'` to display what the current stem setting is but wondered if actual skin buttons can do the same. I've looked at the 'button' page of the wiki & can't see anything to indicate it can but thought I would ask.
I know I could create a custom button wherever i want on my skin but didn't want to litter my skin with custom buttons & keep track of how many I had, so I am just curious if there is a neater solution.
HI
Please ignore my previous post, as I was typing it out an idea started to form & when I went back to the WiKi to double check my post was correct I noticed the action="" tag as a child of "text", which does what I want it to do so thanks anyway.
I wish there was a word for that, "when composing a message to ask for help an idea strikes", because it is a thing
Yes it happens to me a lot & sometimes I even get to the answer before pressing 'Save' on the message which is great & saves some time for everyone.
Follow up question if that is ok, is there a way to mix static text & a query in the button text
My button currently has the following text child
<text fontsize="10" weight="bold" align="center" action="setting 'stemsRealtimeSeparation'"/>
But it would be great if I could precede the setting value with what the setting is e.g. "STEMS Always" rather than just "Always".
get_text &quot;MY TEXT&quot;
I have a button/menu on my skin that show "short" names of the current realtime stems setting
setting stemsRealtimeSeparation 'Fully disabled' ? get_text 'OFF' : get_text `setting 'stemsRealtimeSeparation' & param_cast text 7 & param_uppercase`
My Menu: attention you must give a class
<menu class="[YOUREBUTTONCLASS]" fontsize="11" x="+6" y="+5" width="66" height="25" textaction="setting stemsRealtimeSeparation 'Fully disabled' ? get_text 'OFF' : get_text `setting 'stemsRealtimeSeparation' & param_cast text 7 & param_uppercase`" query="setting stemsRealtimeSeparation 'Always' ? on : setting stemsRealtimeSeparation 'On-Demand' ? on : off" visibility="var_equal '@$eventstem_23' 1">
<item text="Always" action="setting stemsRealtimeSeparation 'Always'" check="setting stemsRealtimeSeparation 'Always'"/>
<item text="On-Demand" action="setting stemsRealtimeSeparation 'On-Demand'" check="setting stemsRealtimeSeparation 'On-Demand'"/>
<item text="Prepared" action="setting stemsRealtimeSeparation 'Prepared'" check="setting stemsRealtimeSeparation 'Prepared'"/>
<item text="Reduced Quality" action="setting stemsRealtimeSeparation 'Reduced quality'" check="setting stemsRealtimeSeparation 'Reduced quality'"/>
<separator/>
<item text="Fully Disabled" action="setting stemsRealtimeSeparation 'Fully disabled'" check="setting stemsRealtimeSeparation 'Fully disabled'"/>
</menu>
For your long name use for example:
setting stemsRealtimeSeparation 'Always' ? get_text 'STEMS Always' : setting stemsRealtimeSeparation 'On-Demand' ? get_text 'STEMS On-Demand' : setting stemsRealtimeSeparation 'Prepared' ? get_text 'STEMS Prepared' : setting stemsRealtimeSeparation 'Reduced quality' ? get_text 'STEMS Reduced Quality' : setting stemsRealtimeSeparation 'Fully disabled' ? get_text 'STEMS Disabled' : nothing
other example:
param_add &quot;`setting stemsRealtimeSeparation`&quot; &quot;get_text 'STEMS '&quot;
DennYo Beats wrote :
param_add "`setting stemsRealtimeSeparation`" "get_text 'STEMS '"
That little script was perfect for my needs, thanks.
I forgot to say thank you for the details response, the other code snippets you included have given me more insight into vdj script & have already used your 'short name' code for a custom 'sort' button i have.
hi at all.. i would map 2 deck buttons in my controller that set fx “pre” or “post” fader:
- button 1: setting “fxprocessing” “prefader”
- button 2: settinga “fxprocessing” “postfader”
but this change fx about all 4 decks…is there a script that change this only in deck focused? thanks!!
no, pre/post is a global setting.
I made a volume plugin, if you use that as the last thing in the fx chain you can use post and still have volume control when you want pre
hi…there is new script “stems_split”…is there a script for make same thing without stems separation? Like “Pioneer DuaDeck”…to control in deck 1-3 play, cue, hotcues, scratch at same time…thanks!!
After using stems_split you could enable the muted stems again to just have a cloned deck
Apologies if this has been asked before but I have a Video Skin and wanted to have text at the bottom of the screen that encourages people to use ask.the.dj.
I am using a textzone with different font sizes & wanted the text to align to the bottom or center of the text line itself however all the text is aligning to the top of the text line.
This is my code, I have looked at the skin wiki but I must be misunderstanding something because it doesn't work as all text is aligned to the top despite the wiki saying it would align center if nothing is specified.
<textzone group="horizontal" align="center">
<size width="1920" height="80" />
<pos x="+0" y="+0"/>
<text font="Helvetica" size="70" weight="bold" color="yellow" valign="bottom" format="ask me or visit "/>
<text font="Helvetica" size="80" weight="bold" color="white" valign="bottom" format="ask.the.dj"/>
<text font="Helvetica" size="70" weight="bold" color="yellow" valign="bottom" format=" for music requests"/>
<text font="Helvetica" size="60" weight="bold" color="yellow" valign="bottom" format=" (pls don't flood)."/>
</textzone>
I have discovered that If I put a 'valign' statement in the <textzone> line, the whole line of text will be aligned accordingly to either the top, center or bottom of the textzone item, altho it still aligns all text to the top of the text line, however this is not documented if I am reading the wiki correctly.
Anway if anyone can shed any light on what I am doing wrong I would greatly appreciate it.
That align is left|right|center
valign is for cases of vertical text, like above but rotated 90degs
66%
