Topic: repeat_start oddness
Rsi & rs scripts appear global, i can turn one on from one side i can turn it off on the other.
If i activate a rsi from a plugin, i can monitor if it is running out side the plugin with
repeat_start 'name' ? This : that
But i can't stop it from outside the plugin, not the end of the world but
Just wondering is this a bug or something missed or even a limitation?
geposted Thu 31 May 18 @ 4:38 pm
The deck should match I think.
geposted Thu 31 May 18 @ 4:50 pm
Not what I've seen, pad on the right side starts a rsi, pad on the left, can monitor if it's running with no deck specified.
I've thought rsi's are global since they came out.
geposted Thu 31 May 18 @ 5:15 pm
