Recently after a while of mixing my VDJ will randomly apply -12 key to a song obviously messing up my mixing and set bpm / tempo. I am usually entering song names with a keyboard while I'm mixing. Is there a keyboard shortcut that i am maybe hitting whilst typing for -12 key? any help greatly welcomed. I currently have the controls in the option set to my Numark controller. Thanks in advance!
geposted Sat 02 Jun 18 @ 1:15 am
No, there's no keyboard shortcut assigned to any key function on factory keyboard mapper.
On the other hand, if you have "key" panel visible on your skin, is there any chance you clicked the "=" button on it ?
geposted Sat 02 Jun 18 @ 9:11 am
Do you have any POI in the beginning of the song? did you mapped key move on your keyboard?
geposted Sat 02 Jun 18 @ 10:39 am
PhantomDeejay - The key panel is visible (I am using the default skin) but there is no "=" key on it only a "+" a "-" and a padlock button.
ohshit - Sorry to sound stupid but what is POI and i havnt mapped any custom buttons on my keyboard they are all as default
geposted Sun 03 Jun 18 @ 8:12 am
Yateseyuk wrote :
what is POI
Start here -> https://www.virtualdj.com/manuals/virtualdj8/index.html
geposted Sun 03 Jun 18 @ 8:15 am
