Topic: Best shaders from ShaderToy - Page: 3
clicked on shadertoy links... got nothing in preview windows.
so with IE - didn't work (but did yesterday)
tried with Edge - worked
tried with Chrome - worked
tried with Firefox - worked
WebGL (code for the shaders) should work in IE 11 (from 2013) or later.
except when it doesn't. no big deal to open in other browser but just a heads up
and can't connect when trying to add a new shader?
acw_dj wrote :
Hello Guys,
I have some shaders that work in VirtualDJ actually, some are animations some others are cool visualizations... Here the list:
Try to down a little Pay of the List , but Virtual Dj says ever (Can't download it , it is not compatible with Virtual DJ) !!!!
And there is a Text this is not Licensed for use in Thirt Party tools ...
What is this ? :-(
groovindj wrote :
Leneer, in your playlist, this one (Colored Steam) is apparently not compatible with Virtual DJ.
https://www.shadertoy.com/view/4sdfDS | view on shadertoy | copy link
This one https://www.shadertoy.com/view/Mld3Rn | view on shadertoy | copy link is really pin sharp on the Shadertoy site, but pixelated and blocky in VDJ. Anyone know why?
Another with problems in VDJ - https://www.shadertoy.com/view/Xsdczr | view on shadertoy | copy link runs fine on the site, but in VDJ gives a large black rectangle with the effect only at the edges.
Sorry, I just saw your problem,about the problem of not being able to use the shader,There are some incompatible shaders that are really beautiful, so I collected them,hopefully one day it will be compatible,so the VirtualDJ tip/prompt is not compatible.
Some may be due to the performance of the graphics card and software version,but most shaders should be available,I added a lot of new shaders again,I hope you like it:)
I also look forward to sharing your collection of colorers with us.hahaha...
https://www.shadertoy.com/playlist/NltcWN
Collection of colorers?
djdutschi wrote :
acw_dj wrote :
Hello Guys,
What is this ? :-(
had same thing happen then for some reason they still installed and played. it was a little confusing.
A favour anyone, my machine is horrific for shaders but can manage the default geometry, (and get nice results with 10 vfx applied) could someone list some super low res shaders.
My 10 year old Asus x58l with Intel onboard grahics, win 10 pro 64bit, 3gb ram and 2.4ghz core2duo cpu runs geometry, Cops are coming !(dont get shot), BTO Dojo Geometry, Fun With Julia Sets Part 3, vinyl visualizer, and soundeclipse rpm.
Even if you have a fast gpu it might be worth using less demanding shaders.
Shaders with low gpu requirements.
https://www.shadertoy.com/view/ls3BDH | view on shadertoy | copy link https://www.shadertoy.com/view/XlcXDX | view on shadertoy | copy link https://www.shadertoy.com/view/4lV3zW | view on shadertoy | copy link https://www.shadertoy.com/view/MsKXz1 | view on shadertoy | copy link https://www.shadertoy.com/view/XsjSWd | view on shadertoy | copy link (Cops are coming - Nice one) https://www.shadertoy.com/view/Ms23zy | view on shadertoy | copy link https://www.shadertoy.com/view/MsS3Dw | view on shadertoy | copy link https://www.shadertoy.com/view/lltSRf | view on shadertoy | copy link https://www.shadertoy.com/view/Mty3Rz | view on shadertoy | copy link https://www.shadertoy.com/view/4tlXWX | view on shadertoy | copy link https://www.shadertoy.com/view/XsBGRc | view on shadertoy | copy link https://www.shadertoy.com/view/XdlyWr | view on shadertoy | copy link https://www.shadertoy.com/view/Xl3XWX | view on shadertoy | copy link https://www.shadertoy.com/view/ls2Gzc | view on shadertoy | copy link https://www.shadertoy.com/view/4dSBR3 | view on shadertoy | copy link https://www.shadertoy.com/view/ltdXzX | view on shadertoy | copy link https://www.shadertoy.com/view/Xs33z4 | view on shadertoy | copy link https://www.shadertoy.com/view/4tlBD4 | view on shadertoy | copy link https://www.shadertoy.com/view/4t3SWX | view on shadertoy | copy link https://www.shadertoy.com/view/4sXGW4 | view on shadertoy | copy link
Nice one ron.
https://www.shadertoy.com/view/MdVBWz grid_0 https://www.shadertoy.com/view/Msy3RD | view on shadertoy | copy link smooth gliders https://www.shadertoy.com/view/lt33Df | view on shadertoy | copy link rainbow audio visualizer https://www.shadertoy.com/view/4lfSW4 | view on shadertoy | copy link reactive voxel https://www.shadertoy.com/view/4tf3zs | view on shadertoy | copy link worm bubbles https://www.shadertoy.com/view/MdBGDK | view on shadertoy | copy link ribbon assault https://www.shadertoy.com/view/MsGBz3 | view on shadertoy | copy link space rings https://www.shadertoy.com/view/4ttGDH | view on shadertoy | copy link abstract gassy field https://www.shadertoy.com/view/Xd2GR3 | view on shadertoy | copy link hexagons distance.
I had 84 shaders running at one point, I found after testing them all out for nearly 3 hrs ( I used to have a life....) that 8 of them made VDJ's waveform move very erratically and the CPU spiked which in turn made the laptop run very hot causing the fans to kick in hard, so I gave them the steel toe cap boot. I now have 76 shaders all running very smoothly with zero issues. However, There is one shader I want that will not work, it's called Knotting by shezard who has not been seen since 2017. https://www.shadertoy.com/view/lt23WK | view on shadertoy | copy link (see image below). Can anyone else get this to work as all I get is a black screen.
Laptop Specs:
GT73EVR 7RF Titan Pro
Intel® Core™ i7 7700HQ @2.80Ghz
GeForce® GTX 1080 with 8GB GDDR5X
16GB DDR4 Ram
W10 Pro
Nope just blank here too and your gpu will be way better than mine.
warning screen on download and black screen on activation.
gonna guess it's a no-go
oh well, Thanks for trying though (Dammit!)
Works fine @25fps on the web site via Firefox, but nothing in VDJ.
I'm sticking with shaders that run at @60fps on their website using my working laptop and it all works great!
30%
