Topic: 2018 Early Access (HELP)
I really like it. But I had to uninstall it and go back to previous version, because I coudn't find the option to remove the song title and Turntable spinning at the bottom.
I run Karaoke almost every Night I DJ. It got in the way of the words on screen. This is a major issue. I went through all the settings and options to turn it off. Read the wiki update and versions to find anything I could to remove it or turn it off and there was no information.
You guys should install a button to go back to previous version of install or and UNDO button for deletions or changes in settings Sometimes I move stuff into virtual folders, that I didn't mean too.... An Undo Last action Button would be AMAZING!!!
Thanks Guys you all Rock!!!
geposted Fri 08 Jun 18 @ 3:08 am
geposted Fri 08 Jun 18 @ 3:39 am
