When I push any of the Cue buttons on the software or on the controller, the Loop function activates and I have to quickly click on it to turn the loop off. Only happens on Deck 1, and like I said using computer or controller, so it's definitely software. Any ideas on where that could be programmed incorrectly or how to fix it?
geposted Fri 08 Jun 18 @ 2:43 pm
Try resetting the controller to factory default programming.
Drop down box in the controller tab within Settings.
geposted Fri 08 Jun 18 @ 2:45 pm
Check the pad page for that deck isn't set to cueloop. It should be hotcues.
geposted Fri 08 Jun 18 @ 2:47 pm
It was the Cueloop setting. Looked right at that several times and never saw it. Thanks @kradcliffe !
geposted Fri 08 Jun 18 @ 3:37 pm
Well spotted Keith. I went past that step.
geposted Fri 08 Jun 18 @ 3:47 pm
That was an easy one Dan ;)
geposted Fri 08 Jun 18 @ 4:00 pm
