Good morning
did you select the MP4 format in the recording tab?
geposted Tue 21 Feb 23 @ 7:57 pm
PhantomDeejay wrote :
As it says, it waits for sound to be played.
Therefore:
1) If you don't have a Record line on your sound setup, turn up the fader of a deck, hit play and it should start recording.
2) If you DO have a Record line on your sound setup make sure it's getting sound (check cables, connections, e.t.c.)
You can turn off the setting that waits for sound before the recording starts, but it won't resolve your problem if cases 1 & 2 are not valid...
Therefore:
I have a pioneer flx 4 and I connected my laptop to my jbl Xtreme using Bluetooth so the sound from the mixer comes from my speaker, but when I go to record it says waiting for audio to play.
geposted Fri 17 Jan 25 @ 7:55 pm
