I have multiple drops on the sampler pad that sync with my controller. My problem is the drop won't play and my folder that has the drops in it are designated at the desktop where the file path originates to. What am I doing wrong or how can I fix this?
geposted Mon 11 Jun 18 @ 6:02 pm
Where did you get these samples, and what format are they in? Do they play OK in the decks?
When you say they don't play, are you sure they really don't play at all, or is it that you just can't hear them (sample volume down)?
geposted Mon 11 Jun 18 @ 6:09 pm
