Topic: Couple questons about new versio
djekipPRO InfinityMember since 2010
Missing some setup tag, or why my active deck dosn't change when i load new track in.. not a big problem, but it was easier to see new track on waveform when it wasn't dimmed. Using 2 pioneer cdj if that matters.
second one how long before your set you can send request on ask.the.dj or none if comp is not online?
Third one is mapping thing is there way to setup cdj rotary wheels so that on rightside player 1 just roll on folders and the second one just on song side? they are using same map file, so can they tell the difference?
Thanks in advance
-Eki-
geposted Sun 17 Jun 18 @ 7:49 pm
You have to be online to get request from ask the DJ. You can have different venues, but you have to be at one, to get the info. It's location based. You can be at home, but you would have to tell your guest where you are. How will you do that, group text, twitter?
geposted Wed 20 Jun 18 @ 5:30 am
For your third question, you can use "action_deck" query in order to make the jogs behave differently.
As an example:
action_deck 1 ? browser_window 'folders' ? browser_scroll : browser_window 'folders' & browser_scroll : action_deck 2 ? browser_window 'songs' ? browser_scroll : browser_window 'songs' & browser_scroll
The code above will make the left jog scroll the folders and the right to scroll the songs. However, the jogs won't control the song under any case (if that's what you want)
geposted Wed 20 Jun 18 @ 7:30 am
