Hi. im using VDJ8 pro with ddj rb but cannot use headphone cue on the rrb. Any ideas? Headphone cue works perfect with rekordbox on DDJ RB.
geposted Mon 18 Jun 18 @ 8:15 pm
Working fine here on my RB
have you tried clicking the RB icon in the audio config page?
otherwise post a screen shot of you audio confin in VDJ so we can see what you have.
Also there is a nice manual for the RB here https://www.virtualdj.com/manuals/hardware/pioneer/ddjrb.html
geposted Mon 18 Jun 18 @ 8:23 pm
hi heres a snapshot
geposted Mon 18 Jun 18 @ 9:01 pm
Any ideas anyone. Everything works fine with rekordbox but I can't use headphone cue in ddj rb
geposted Mon 18 Jun 18 @ 9:02 pm
I've changed the master 1/2 and headphone 3/4 to ddj rb ASIO and all is good finally with the ddj rb headphone cue issue. Deffo had a fault somewhere earlier as I couldn't delete these configs.
geposted Mon 18 Jun 18 @ 9:32 pm
why is 2 sound cards selected?
both master and headphones should be on ASIO
geposted Mon 18 Jun 18 @ 9:47 pm
Hello sir,
Since i am using PIONEER DDJ-RB with rekordbox its working perfectly but i am having issues using it with virtualdj 8.
The only problem is my headphones are not working on cue mode
They are only working on master mode
I have changed the settings in every mode.
I choose DDJ RB ASIO 1/2 For master and 3/4 for headphones as output.
Kindly suggest me.
Kindly suggest me.
geposted Fri 22 Feb 19 @ 7:03 pm
