also the reason we think your using the Bluetooth and maybe don't realize it is because the speaker name is here instead of the onboard sound of the laptop.
geposted Sat 30 Jun 18 @ 5:49 pm
Sorry for the late response. The speakers are EV's 12's connected by cord not bluetooth. I did turn off bluetooth and it did it again.
geposted Sun 01 Jul 18 @ 4:37 pm
But what are they connected to?
You should make sure that the correct device is selected in virtualdj audio settings then
geposted Sun 01 Jul 18 @ 4:39 pm
Okay I'll check.
Speakers are connected to a crossover - then out to the mixing board - i also have a 18in Sub powered by a amp that runs to crossover - then to board.
geposted Sun 01 Jul 18 @ 4:42 pm
Somehow I don't think that's for home use...
geposted Sun 01 Jul 18 @ 4:47 pm
Is this better as I checked mixer and headphones ?
https://www.dropbox.com/s/38pu3p737oy8ecj/Photo%20Jul%2001%2C%2012%2045%2001%20PM.jpg?dl=0
geposted Sun 01 Jul 18 @ 4:50 pm
It's home use, but would this go away with a paid version or is it the same ?
geposted Sun 01 Jul 18 @ 4:51 pm
I've never had this problem before over all these years.
geposted Sun 01 Jul 18 @ 5:02 pm
paying for it wont make the issue disappear
do you still have the problem with the realtek device selected? if so search out updated drives and make sure none of the built in FX are active in windows.
geposted Sun 01 Jul 18 @ 5:14 pm
I'll try it like this and see if it happens, and all my drives are up to date.
geposted Sun 01 Jul 18 @ 5:16 pm
Where are your headphones connected to? Your realtek only seems to have a single output, so the headphone output will not work like that
geposted Sun 01 Jul 18 @ 5:34 pm
I don't have headphones. I just checked it since I have a line out coming out of the headphone jack. I really don't know what to have checked.
geposted Sun 01 Jul 18 @ 5:36 pm
If you only have speakers it should be speakers only
geposted Sun 01 Jul 18 @ 5:58 pm
Okay, why would it make the songs playback wrong ?
geposted Sun 01 Jul 18 @ 6:44 pm
If you just have a pair of headphones plugged into the laptop rather than your huge PA system, does the audio still skip?
geposted Sun 01 Jul 18 @ 6:47 pm
Yes sir it does.
geposted Sun 01 Jul 18 @ 6:48 pm
OK so the issue is definitely within the computer itself...
Have you run a latency checker on it?
geposted Sun 01 Jul 18 @ 7:27 pm
when it happnens, what happens if you press apply in audio config?
geposted Sun 01 Jul 18 @ 7:41 pm
Well it's a new computer so I hope not!
geposted Sun 01 Jul 18 @ 8:16 pm
I've never hit apply while it's happening, and what would I be applying ?
Also, I believe it has to be something during the loading of the song.
Of course I could be wrong.
Yesterday it did it, and I loaded the next song and it did it again.
geposted Sun 01 Jul 18 @ 8:18 pm
