Hi, Sorry if I have gone to the wrong forum, I am using the new 2018 software and have noticed the song now overlays on the video screen, is there was of turning this off?
geposted Wed 20 Jun 18 @ 10:16 am
bottom of this image where it says video skin select none
geposted Wed 20 Jun 18 @ 10:18 am
Why is it even turned on by default anyway?
geposted Wed 20 Jun 18 @ 10:20 am
Exposure, better to make people aware the feature exists and let them turn it off if they choose, than folk never finding out it's an option.
geposted Wed 20 Jun 18 @ 10:29 am
Well at least there should be a pop-up telling people how to turn it off .... especially since the manuals haven't been updated yet.
Not everyone is savvy enough to figure out where the video skin option actually is.
geposted Wed 20 Jun 18 @ 10:43 am
Thanks for your help, was looking in the settings menu assumed that was where it would be!
geposted Wed 20 Jun 18 @ 10:46 am
There's an option now in the latest build 4444
useVideoSkin
useVideoSkin
geposted Wed 20 Jun 18 @ 10:48 am
There is a pop up for anyone who downloaded since 10th June and activated video for the first time.
Anyone who had the very first EA release won’t see this pop up, unless they install from the website installer.
geposted Wed 20 Jun 18 @ 2:20 pm
Is there a way to edit this and make it only visible for 10-15seconds?
geposted Sun 29 Jul 18 @ 12:34 am
Maybe... when though?
geposted Sun 29 Jul 18 @ 12:54 am
Edit what? There's more than one videoskin.
There are more available for download, including one designed for briefly displaying track titles.
geposted Sun 29 Jul 18 @ 8:56 am
for that i think this is your only option https://www.virtualdj.com/plugins/index.html?addonid=80812
geposted Sun 29 Jul 18 @ 12:56 pm
Not the only option, because whatever XML code is used in the Title videoskin to make it appear for X seconds, could be added to whatever other videoskin the user chooses, to make that do the same.
geposted Sun 29 Jul 18 @ 1:19 pm
can you provide a working example please?
geposted Sun 29 Jul 18 @ 4:26 pm
That's something for the skin forum really, not here.
geposted Sun 29 Jul 18 @ 4:29 pm
I am sure nobody will mind if you post that example in the skins forum thanks :-)
geposted Sun 29 Jul 18 @ 4:40 pm
Why don't you start the ball rolling by posting which videoskin you'd like modified, which part(s) you want modified, and how long you want the part(s) to remain on screen?
geposted Sun 29 Jul 18 @ 5:14 pm
