Hi for some reason under master it no longer gives me an option to add text over my videos nor does it show up in settings (text). Using the current version of VDJ it was working but one day it just disappeared when I reinstalled it. I tried to re install again but no go. Also there is no option to put on the webcam either. Went back to default skin and still nothing.
geposted Thu 21 Jun 18 @ 5:31 pm
The Text Plugin should be available in the Video Effects list. and the Camera in the Video Source list.
If you load a Video track on a deck, it will automatically switch to the "Advanced" Video view and you will get the same view you had before the update, where everything you ask is available under the Video Effects drop-down list.
geposted Thu 21 Jun 18 @ 6:06 pm
