Topic: Is the new Pioneer DDJ-400 controller supported by VirtualDJ? - Page: 1
Hi guys, I would like to know if the new entry-level controller Pioneer DDJ-400 is supported or is going to be supported by VirtualDJ software...
I know that I will be able to map buttons, sliders, knobs and pads anyway but I will probably not be able to map the LEDs if VirtualDJ doesn't support the console, right?
Let me know, thanks!
geposted Sun 01 Jul 18 @ 12:25 am
1) Atomix never provide dates for support of controllers. It will be "when it's ready".
2) Any VDJ user can map a controller by writing definition and mapping files. Details in the wiki.
I've seen there is a "Cooming soon" section here on the website anyways...
http://www.virtualdj.com/wiki/VirtualDJ8%20Controllers.html
As I said before, I know but mapping LEDs is a little bit more complicated they may require System Exclusive MIDI Messages.
As you said I've seen that VirtualDJ supports controller definition file some time ago which is great I will try that in case as soon as I get the device... ;)
Thanks for the information. Is it foreseeable until when the mapping will be available? So it lulls months or just 4 weeks that's the question behind it.
As stated, VDJ does not give timelines. You're lucking though, because they also stated that it's "coming soon", which means they are working on it, as well as other controllers. Don't worry, when it's done they release it.
I recently purchased the DDJ400 myself and am not a fan of Rekordbox or Serato, my preference if Virtual DJ as I have all my hotcues etc all ready set and I don't want to have to start going through music again to do this in the other software, TBH, I think Virtual DJ is a better software
I should have done abit more research as I wasn't aware the DDJ400 isn't compatible with Virtual DJ but if any one has any indication as to when this will likely be I would appreciate it. if its not anytime soon I may leave the controller back and use my other controller that I can use with Virtual DJ
thanks
The post directly above yours, djdad states it's in beta and you can help.
We have pushed the mapping files for Pioneer DDJ-400 as a silent patch for the current Early Access (Build 4514)
So in order to have your DDJ-400 working with VirtualDJ, you will need to ..
1. Enable EarlyAccessUpdates setting from VDJ Settings->OPTIONS tab
2. Restart VirtualDJ and wait for the updated Build to be downloaded.
3. Accept the Update
4. Once VDJ is opened, wait for a few seconds and then restart.
If you are on Build 4514 (Early Access), you just need to follow Step 4.
If not working, verify that you have a controllers.dat file in /Documents/VirtualDJ/Devices folder. If not repeat the steps above.
Hi
I have just done this and Virtual DJ works with the DDJ400, I am so happy now, was going to sell my DDJ400 but think I might hang onto it, is this ok to use in gigs etc?
owentreanor wrote :
Hi
I would say yes
- The build is still an Early Acces build, but the devs wrote yesterday, that unless a bad bug is found soon, it will be the next public build - so it should be pretty safe
- The mapping is just a mapping. So if it works the first time you push a button, it will also work and do the same the next time you press the button.
So if you find it to be valid for all you are doing when you test it at home, you should be good to go
frankinioul wrote :
[quote=frankinioul][quote=djdad]We have pushed the mapping files for Pioneer DDJ-400 as a silent patch for the current Early Access (Build 4514)
un grand merci à la personne qui à pris le temp de donner une explication concernent le pioneer dj ddj-400 jais aussi pu suivre les instructions est je suis content d'avoir pu configurer mon controleur dj ddj-400
vais me remettre tout doucement a refaire des set,, d ici peu sortira le dj virtuel pour ddj-400 faudra til l 'installer ou laisser selui qui a été modifier merci encore ,,,francois
je ne c est pas se qu'il ses passer mes lorsque je relie se que jais écrit je voie des mot qui ne veule rien dire allors que je vien de relire mon écriture donc désolé bizard,, bonne soirée à tous
This is an English speaking forum only. Please post in English, or try our French forum located, here, thank you.
can any one email me the mappings for the ddj 400 thanks @ email removed
Sorry non license holders are not permitted to post email addresses.
It's included in the software. So there are no mapping files.
Simply download the latest version and upgrade, and you are good to go
Is anybody else not getting any master output sound in their headphones? Everything else seems to work as expected but, no matter what I do, I get silence when I turn the cue/master knob to master. When I turn the knob to cue, I hear the cued deck just fine.
You need to enable the master cue button under the master level knob for it to work.
This is a little strange, but I think it's a hardware thing that Pioneer has recently started adding.
The cue/master knob is also hardware based, so it's actually the unit and not the software that handles it (the heaphones and masster volume on the unit are also hardware based - I believe the rest is midi)
Edit: It's mentioned in the VDJ hardware manual under point 25, but maybe it should also be mentioned under point 22
http://www.virtualdj.com/manuals/hardware/pioneer/ddj400/controls.html
Interesting. You're the man! I should read the manual before running to the forums next time. Thank you for everything you do!!
[quote=Luigi Piscopo (DJ Gi)]Hi guys, I would like to know if the new entry-level controller Pioneer DDJ-400 is supported or is going to be supported by VirtualDJ software...
Let me know, thanks![/ salut à tous mon controleur dj ddj-400 ne repond plus il me dit avec un usage priver domestique c gratuit meme tout les diminute il repond plus a t il une mise a jour à faire est ou la prendre merci
VDJ does support the console, since build 4514 released 31/07/2018 (see earlier messages).
bonjour le virtual dj ne fonction plus corectement apret 10 minutes il me demande de acheter le produit,, au debut demandai payer pour dj pro essaye de 30 jour a present meme avec version domestique me demande des comptes merci de me donner une explicationbon dimanche francois
56%
