Hello I'm hoping I can get some help. I am running VDJ 8 2018 on a mid 2015 MBP i7 2.5 ghz, 16gb, 500gb hd, and a pioneer ddj sx2. My issue is this, since the last two vdj updates the backspin feature produces no sound, regardless if used on the jog wheels or using the button on the laptop. This is the same whether the controller is connected, or vdj is being operated on the mac only. Is this intentional or am I doing something wrong. Thank you in advance for any assistance.
geposted Thu 05 Jul 18 @ 7:16 am
set smartscratch off could help...
geposted Thu 05 Jul 18 @ 7:37 am
music234 is probably right.
In the GUI it's this setting:
geposted Thu 05 Jul 18 @ 8:00 am
Thank you very much!!!! Smart scratch was the issue. I really appreciate the help.
Mod : solved and locked
geposted Thu 05 Jul 18 @ 9:11 am
Go to settings and go to vinyl setting make sure it on, and set smart scratch to on. Problem solved.
geposted Sat 29 Aug 20 @ 3:30 am
