Topic: PIONEER DJM900 NEXUS MIXER Crossfader mapping
Hi guys
is it possible to get the PIONEER DJM900 NEXUS MIXER crossfader to also move the program's crossfader and be able to video mix and transition without having to move it with the mouse on the laptop?
geposted Wed 11 Jul 18 @ 5:52 pm
The default mapping already has the crossfader mapped, so it should move the on-screen crossfader - if you have everything set up correctly.
geposted Wed 11 Jul 18 @ 6:17 pm
You want to link the Vxf to the audio xf, it's there as an option on the video panel on the default skin.
geposted Wed 11 Jul 18 @ 6:47 pm
freppaPRO InfinityMember since 2002
Hey Vybez.
If you have the mixer pluged in and using the default mapping as groovin says, you should be able to change your settings as locodog saying.
Here is the small button on the original skin.
geposted Wed 11 Jul 18 @ 7:31 pm
@Vj Vybez, does this solve your problem?
geposted Wed 11 Jul 18 @ 10:56 pm
