Topic: DVS noob question, can i remap buttons on the mixer.
PsyntexHome userMember since 2018For instance i have 4 cue buttons on my mixer i don't really use and i was wondering if there was a way to somehow program the mixer cue buttons to one of the buttons in virtual dj like flanger,sync,loop etc
Regardsgeposted Thu 12 Jul 18 @ 2:18 am
groovindjPRO InfinityMember since 2007Yes, MIDI buttons can be remapped. That's the whole idea of mapping - change it to suit your needs.
Don't you think it might be helpful to state exactly what mixer you want to use? Not all mixers have MIDI mapping capability.
BTW how are you going to cue if you don't have cue buttons?geposted Thu 12 Jul 18 @ 6:37 am
PsyntexHome userMember since 2018Its a pioneer djm250 mk2, and i cue by putting the needle on the vinylgeposted Thu 12 Jul 18 @ 5:09 pm
kradcliffePRO InfinityMember since 2008It's not supported yet so you can't map anything at present.
geposted Thu 12 Jul 18 @ 5:18 pm
PsyntexHome userMember since 2018Ok thank you guess i need a new mixer!geposted Thu 12 Jul 18 @ 5:23 pm
Dan (djtouchdan)PRO InfinityStaffMember since 2008You don’t need a new mixer. Just some patience until it’s supported. geposted Thu 12 Jul 18 @ 5:34 pm
groovindjPRO InfinityMember since 2007You can still map basic functions like the cue button, without native support.
Yes, putting the stylus on the vinyl is the first part of cueing, but you still need to put the mixer into cue mode to pre-listen to the track... geposted Fri 13 Jul 18 @ 5:15 am
visionz5PRO InfinityMember since 2011You'll have to upgrade your license too since Home Users cant use unsupported hardware or time code
