I'm using the numark mix party, and when i have a song cued on deck 2 and increase the volume, when it gets nearer the top the volume/quality decreases on deck 1. i could upload a sample if anyone wants.
geposted Sat 14 Jul 18 @ 5:55 pm
Sounds like you're triggering the limiter - i.e. too much volume.
geposted Sat 14 Jul 18 @ 6:12 pm
i turned all knobs to 12 oclock, even turned the bass right down on the cued song but its still happening.
geposted Sat 14 Jul 18 @ 7:02 pm
Still most likely that your signals are too hot, try change the setting zeroDB to -6.
The first thing (technical/electronical) I leant about dj'ing is if it's too quiet and it's up full/high, try turn it down, counter intuitive but true.
Would you rather?; as loud as possible with the limiter messing up your mix, or better idea turning it down a bit and having smooth levels.
geposted Sat 14 Jul 18 @ 8:39 pm
how do i do that?
geposted Sat 14 Jul 18 @ 10:51 pm
Just like that.
geposted Sat 14 Jul 18 @ 10:54 pm
this has stopped it, but the tracks still sound like they aren't gelling together that well, just kinda sounds like one song on top of the other if you know what i mean.
geposted Sun 15 Jul 18 @ 11:53 am
3 tips to help with that
-It will depend on the songs if they will fit together at the same time or not
-It will depend on the locations within the song. When both songs have a vocal or main instrument playing at the time you try to mix it, that will often not sound well together. Do your mixing in the intro's/outro's where less is going on
-Use the low equalizer to make sure kick and bass of only one of the 2 songs is fully open at the same time
geposted Sun 15 Jul 18 @ 12:00 pm
I've used VDJ for quite a while, but just with the laptop, and I've never had this problem this is the first time using a controller and the new version, and it just doesn't sound right.
geposted Sun 15 Jul 18 @ 12:08 pm
Well come on - what do you expect for a low end, budget 'toy' controller?
Quite possibly the audio interface in that thing is worse than what's in the laptop!
geposted Sun 15 Jul 18 @ 12:17 pm
Can you make a short recording perhaps, both with the old version and your current setup.
It's a bit hard to tell what you hear is 'wrong' just by what you explained
geposted Sun 15 Jul 18 @ 12:30 pm
