Topic: Cue not working on one deck
djkrysrPRO InfinityMember since 2010
I have had a problem occur twice now where the cue button on one deck stops working.
On my controller the cue button is mapped to "play ? cue_stop : goto cue 1" so that it won't set a cue if the track isn't playing.
It works perfectly until all of a sudden it stops working, I load a track, pre listen to checkj, then hit the cue button but the track keeps playing. I have noticed that every time I hit the cue button a marker appears on the rhythm wave at that point (moving from it's previous position and without any cue name next to it) and if I hit the cue button on the skin the same thing happens, a marker is placed but the track continues to play. The only way to stop the track is to hit the stop button on the skin or hit a button I've programmed to unload the track.
The first time this happened when I loaded a different track it went back to normal, the second time it happened every track on deck 2 behaved the same.
Closing VDJ then restarting it solved the problem.
I tried just mapping "cue_stop" to the cue button, that made no difference. The hot cue buttons "goto cue 1" etc carried on working fine.
Any ideas anyone.
geposted Sat 14 Jul 18 @ 10:21 pm
Any ideas anyone.
Hi! I'm having to same problem. Did you ever solve it? Could you share the solution?
geposted Mon 25 Feb 19 @ 8:25 pm
Funny things can happen when an action does not take everything into account. In that particular case if hotcue 1 exists.
So, change your script to:
play ? cue_stop : has_cue 1 ? goto_cue 1: nothing
geposted Tue 26 Feb 19 @ 7:41 am
ewaziriHome userMember since 2021
Has anyone gotten a solution to this problem
geposted Sat 03 Jul 21 @ 11:04 pm
Try to map a custom button as touchwheel_touch (will be lit if the jog is touched)
Then if it happens again, see if the custom button is lit.
geposted Sun 04 Jul 21 @ 7:20 pm
djjbPRO InfinityMember since 2004
I had the same problem, after touching the jog wheel the problem was solved.
thnx djdad.
geposted Sat 25 Sep 21 @ 8:13 am
