running a 2011 MBP, mixing video, I have the annoying white bar at the top of my video, I've gone to the system preferences/mission control and unchecked "displays have separate spaces" logged out and back in, the bar is gone in the desktop, but is appearing on my projected video, it doesn't seem to make a difference if I'm running video or shader on audio only tracks.
geposted Wed 25 Jul 18 @ 4:32 am
Try the solution from 2nd post here.. https://discussions.apple.com/thread/8084557
geposted Wed 25 Jul 18 @ 12:20 pm
what worked for me was after you open VDJ go to the output window.
1) right click
2)and pick window first
3) then go back to fullscreen
1) right click
geposted Thu 26 Jul 18 @ 4:10 pm
What OS version are you on
geposted Thu 26 Jul 18 @ 4:14 pm
os 10.13.6, sorry, forgot to add that
geposted Fri 27 Jul 18 @ 2:14 am
sorry i can not help i am on 10.10.5
geposted Fri 27 Jul 18 @ 3:22 am
one of my other DJ's had this issue he would just click on the output window close it and reopen it and it went away i do not know if this will help but you can try
geposted Tue 31 Jul 18 @ 5:30 pm
