Topic: local music folder move
Hi
So the other day made the mistake of moving a folder "Music" (shows all my hard drive music). This folder is now a subfolder. IS this possible to reverse? I cant seem to see how.
Simon
geposted Sun 29 Jul 18 @ 1:58 pm
That's just a favourite folder, you left click and hold and drag it to where you want, if under some other folder and to the right you'll insert it in that folder, move to the left of the screen and it should go on the root.
geposted Sun 29 Jul 18 @ 2:12 pm
ok thank you for this.
thank you
Simon
geposted Sun 29 Jul 18 @ 3:08 pm
I honestly can't remember how it was in v7, maybe drag and shift (keyboard) (I think drag and ctrl was copy folder.
I'm not sure where the .vfolder is saved.
in v8 it is in a hidden folder (called folders) inside the the real folder it is nested in.
so for me to have mine on the root it is found in
M:\VirtualDJ\Folders
virtualdj is also a hidden folder
geposted Sun 29 Jul 18 @ 3:15 pm
@simon...
From your web site:
"From 1st June I charge for 4 hours on a Saturday £200"
FYI Controller licenses (which you have) are for home use only. Clearly, from the fact you have a web site containing the above quoted text, you're working professionally. Therefore you need either a full Pro Infinity license or a Pro subscription.
geposted Sun 29 Jul 18 @ 5:27 pm
